R70/71 = 470 ohms
R66/67 = 560 ohms
I am getting -21v and 9v with these resistor values. Zener diodes are 15v rated.
R66 and R67 belongs to one side and R70 and R71 on next two channels.
See attached.
Thank you.
+15 volts is not stable. i removed all the opamps then i got +14.5v on R67 then started to install opamp one by one. when i installed U101 the voltage remain good. then i just plugged in RCA Channel 1 the positive voltage disappeared. when i removed RCA jack i got +14.4v that is very strange.
