Hello Evryone,
I have a pair of JBL 2447 and I'd like to know which horn to use. What's your prefered horn and why? For now I have found :
- JBL PT H1010HF : the lower cost horn but a 100x100. That could be an issue to have 100° on the vertical axis.
JBL 442730-001 PTH1010HF-1 Waveguide - Speaker Exchange
- JBL M2 HORN : I have read good and bad opinion .... the most costly ...
JBL M2 Horn Lens 5025594 - Speaker Exchange
- clone of H9800 : pricely too ...
- JBL PT H64HF : can't find it
- jbl 2352 / 2353 / 2354 : can't find them
Did you know others horns ? Or where to find the others jbl horn stuff ?
Thank you in advance
Wow, what a beast of a compression driver.
Where do you want to cross it ?
I have the older pth1010hf, the newer one is the pth1010hf-1, and reasonably priced.
Rob with his 4" pushes it to 1khz.
Older pt horn is a little smaller dispersion past 5khz, the newer one doesn't and may need more boost.
I love the 2384 for 750hz crossover, some go down to 630hz.
I think my pth horn is a bit cleaner up top, but could be the mustard i had last night.
But those are the only horns i know.
