For Sale - Reference DAC PSU for Red Baron / Tube-I-zator
Posted 28th January 2017 at 11:16 AM by dvb projekt
Updated 8th February 2017 at 06:19 AM by dvb projekt
Reference DAC PSU
Custom made "Galaxy" housing with 10mm front panel from modushop.biz
Custom made Transformer with double C-cores, made for Vacuumschmelze Germany for Siemens military equipment
Tube-Rectifier circuit (6106/GZ34 or equivalent) with High-End Parts for B+ of the Tube-I-zator
The C-L-C-R-C Network with no electrolytic caps!
Yamamoto Teflon socket with gold pins
3.9µF Supreme silver/oil
10H amorph core choke from AE-Europe
47µF TubeCap
2x 100µF Tube Caps (one for each channel)
PRP Resistors incl. bleeder resistor
SED Winged "C" 5U3C (5U4-G) Black Plate rectifier
4 voltage lines à 27.000uF filtering (60x 1.800uF/35V Panasonic FM)
Every line has a Mundorf Supreme 0,1uF decoupling cap and a bleeder resistor
Fairchild Stelth rectifier diodes
Power Switch Module with onboard solid state relays for LV switching of the AC-Power
Furutech FI-03 (G) AC-Inlet
Russian military 24pin Connectors incl. 75cm interconnect cable
Output voltages
189VDC B+ (2x) - for the Tube-I-zator HV-Shunt reg.
13VAC - Heater voltage for Tube-I-zator
14VDC (3x) - for +5V/-5V Red Baron shunt reg. & +5V/3.3V add. shunt reg.
25VDC - for -15V Red Baron shunt reg.
Price: 690,- EURO
incl. DHL worldwide free shipping
You could see additional pictures of the Reference DAC PSU
HERE
47µF TubeCap
Output voltages
Price: 690,- EURO
HERE
Total Comments 0
