Favorite Threads and Posts in this Forum
This permanent thread is a place for links to threads or posts in this particular forum that are useful and/or exemplify the best of DIY Audio.
This is so others- especially newer members can find them. Feel free to post with these links and a brief comment on what the thread discusses. Occasionally the moderators will consolidate them into fewer posts.
Hi
Nice. That is what I would need some years ago and would many others. So to save you some time I will post link to thread that my friend and me made some time back. We didn't like the usage of big toroids as well as big amp to get power higher then something like LM or TDA can provide.
We started together, making full-bridge, with no knowlage of how does it work. To keep everything short, I made instead half-bridge with big help from others on this forum.
If you will read whole thread, you will see what mistake were made so that you won't make them.
This is half-bridge smps, powered from 230Vac, which has a lot of stuff on, that make it good as it is and is more then capable of power of 1kw.
http://www.diyaudio.com/forums/showthread.php?s=&threadid=69111
Hi again
Inrush current limit
Usefull for big trafos and offline smps's
https://www.diyaudio.com/community/...-limited-circuit-from-edn.104793/post-1250985
2-Phase 12-20V Boost ckt
This circuit can be readily adapted to a variety of output voleages and currents: http://www.diyaudio.com/forums/showthread.php?s=&threadid=93310 . Look at post #35.
May I add Jung's Super Regulators discussion
http://www.diyaudio.com/forums/showthread.php?s=&threadid=90502
http://www.diyaudio.com/forums/showthread.php?s=&threadid=20937
My favourite is good old Fred Dieckmann's thread on the LM regulator:
http://www.diyaudio.com/forums/showthread.php?s=&threadid=28978
Basic info on getting iron powder cores online and calculating inductors with them:
http://www.diyaudio.com/forums/showthread.php?postid=1393703#post1393703
This thread should be here.
Bob Cordell interview power supplies.
http://www.diyaudio.com/forums/solid-state/90728-bob-cordell-interview-power-supplies.html
Salas Shunt Regulator - explanation of adjustments and calculations
http://www.diyaudio.com/forums/powe...notize-general-shunt-reg-pcb.html#post1952317
http://www.diyaudio.com/forums/power-supplies/209221-smps-transformer-design-tool-ver-4000-a.html
Here's a full and complex design tool for calculating the SMPS transformer
Hi
Offline full-bridge SMPS....need help - diyAudio
the best of the best in smps
The Quasimodo thread
http://www.diyaudio.com/forums/powe...ber-using-quasimodo-test-jig.html#post3645210
AND:
diyAudio Power Supply Circuit Board v3 illustrated build guide:
http://www.diyaudio.com/forums/powe...circuit-board-v3-illustrated-build-guide.html
21st Century Maida Regulator
One of the best Voltage Regulator for your tube projects.
http://www.diyaudio.com/forums/tubes-valves/209067-21st-century-maida-regulator.html
I skimmed through the posts here but did not see any mention of my favorite thread.
Power Supply Resevoir Size
Not so much a thread but a useful page for roughly sizing transformers to the type of load: http://www.hammondmfg.com/pdf/5c007.pdf
- Power Supplies
- Favorite Threads and Posts in "Power Supplies"
