Pearl Acoustic Sibelius
Its seems that Sibelius is some kind of hybrid between Frugal horn and Pensil. They also have bunch of photos with FH3 (Valentini)
Facebook
Ok, it's a TQWT style of speaker, which is also not that different als a classic MLTL. The sound will be slightly different altough due to the expanding pipe but it uses the same kind of mass loading of a resonance pipe.
I don't know any design that did this for this driver but the Frugalhorn XL. That will probally your best bet for a close match then except a bespoke design (which is expensive). The plans are also on the frugalpile website i linked before, but need a little donation for all the details i thought. If you want to go bespoke, contact Scottmoose (Scott Lindgren from Woden Designs) as he is the specialist on this, and also the guy who made that frugalhorn and Pencil design.
frugal-phile™
Joined 2001
I note that these guys (ie Harley) did talk to Scott as he was putting this together and was also going to do a FH3 derivative for the Alpair 7, but it turned out not to be feasible because it cost essentially the same as the larger one.
So you can be assurred that this design was heavily influenced by the forum.
An example of what the difference between doing it yourself, and buying a similar design done very well in French Oak and sold retail.
Worth the money if you are into buying at the store, but diying your own is the frugal-phile™ way.
dave
Reactions: 2 users
Hello all
I have fallen in love with the Pearl Acoustic Sibelius but can't afford it.
Is it possible to clone it or build something similar? Please advice
Dear peterpan,
well, I stated it as beeing tricky, but that's only half of the truth. If you look at Martin J. King he said that there are three kind of TL cabinets: the straight one, the conical expanding (like a TQWT) and the conical reducing. And when you close one end (SL) it only makes sence at the first two and you add a port (with a smaller area than SL) you get an MLTL. So in the end the Sibelius is an MLTL (a TQWT with a port).
http://www.quarter-wave.com/TLs/TL_Alignments.pdf
Designing Mass-Loaded Transmission Line (MLTL) Speakers – Neurochrome
Conclusion build the Pensil and enjoy it!
Kind regrads from Germany - stay save and healthy!
Stefan
Scott’s Pensil design is a pretty damned easy build - unless you get really anal with internal bracing :eek:, or exotic hardwoods that require higher level of wood craftsmanship. I’ve build several for different models of MA drivers, and A10.3s have served in my small home theater system for at least 5yrs now.
frugal-phile™
Joined 2001
I usually hate YouTubes, but this guy is good (at least the first 5 min).
"Huh, what, wait … this does not sound like a single driver speaker…"
Looks like the pricey speaker he showed looked like a big Audio Nirvana. Says the driver is tweaked a bit.
Does not go as low as FHXL.
dave
Reactions: 1 user
Seems you really liked the review Dave ;) I has looking out for his review for a while and really liked it as well!
For a long time I have been interested in single driver speakers and I've had my eye on a Pensil 11 kit from the earlier mentioned shop for a while now. I like the project and the frugal side of it. However, It seems that there can be big differences between one single driver speaker design and the other. Is there anything that can be said on how close the performance of a diy Pensil could come to a Sibelius speaker where the manufacturer spent a lot of time in optimization?
