It's nothing more than the sum of the power noise of two random and uncorrelated signals, divided by the amount of signals = average.Averaging is a "boxcar" LP filter. LP filtering the noise has the effect of smoothing the noise floor so you get more of an averaged value. However averaging is not the same as reducing the noise per bin (then averaging/smoothing or not).
https://en.wikipedia.org/wiki/Boxcar_averager
That's is not smoothing, that is most definitely averaging the noise out, since the noise is totally random to begin with.
Smoothing would mean that any correlated signals will also be averaged out, which they actually don't.
In fact, if they are strongly correlated they sometimes even get more obvious after averaging.
But again, read your books.
They get averaged too is all. So if there is any variation in their amplitude from each FFT pass what we see after averaging is the average value of the correlated signal. IOW, we are are low pass filtering any "noise" in the correlated signal amplitude.Smoothing would mean that any correlated signals will also be averaged out, which they actually don't.
However, there is an average value of noise Magnitude in the noise floor too, and because most spectral analysis is void of phase information there will be no cancelation. For that you need phase of noise too, not just amplitude.
Use of the word smoothing was in its common language meaning.
Exactly. If we want to reduce RMS noise (and keep all signal-related stuff), we need to apply time-domain averaging first (which then requires sample-synced recording).No, averaging will make the curve smoother. but it will not lower the noise floor.
To reduce the noise floor you need to increase the FFT window size, as done by KSTR above with a 4M-point FFT. Doubling the number of points will reduce the noise floor by 3dB.
Unfortunately the RMS noise stays the same of course.
Noise floor only really has a meaning in the context of effective bandwidth. Higher resolution with a larger FFT chops the bins into smaller pieces with less noise in each but they still add up to the same number for the same bandwidth. The higher resolution enables "seeing" deeper into the noise. Coherent averaging, however, will enable removing noise pretty dramatically revealing stationary signals.
I don't know a lot about the Mac audio subsystem but I can say that Windows will enable sample rate conversion and different bit depth if you don't check or bypass every opportunity for Windows to mess with your audio. if you can use ASIO it's usually better. However even that can run into issues. This is one virtue of the dedicated systems with software (AP, Quantech etc.); those system problems are largely locked out.
The Java based drivers supplied with REW seem to be really good. The macOS one was already good, but a very smart fellow wrote custom drivers for Windows and Linux use in REW. These allow for exclusive access to the devices, too. I haven't found a single case where the Java solution isn't superior to ASIO with REW. At least with recent versions of REW. But, that's just me.
Anyway, I tried running my own Cosmos ADCiso with a MacBook Air M1 just like SylphAudio's and had no problem with the noise floor. (Posted above.) I tried using the same settings as he (she?) did in REW, too. It took me longer to find all the right cables than it did to get it all up and running for the first time.
I suspect that SylphAudio has a bad connection, a subtle setting wrong, or something like that. That's easy to do, and I'm not being critical here. I certainly have experienced all of those.
What do you mean by sample-synched recording? In synch with the digital source? Or preseving the phase? What good would either do here?Exactly. If we want to reduce RMS noise (and keep all signal-related stuff), we need to apply time-domain averaging first (which then requires sample-synced recording).
Is your Mac version Sonoma 14.4.1? Looks like REW can't get exclusive control over the ADCiso since the system treats the ADCiso as a microphone input (and it's applying noise cancellation). I already updated to the latest non-beta REW (5.31.1).Excellent point!
This is my Cosmos ADCiso directly into a MacBook Air M1. Based on his most recent posts, I've adjusted the RTA settings to match his. (I hope) He should be able to compare his results directly.
REW only displays the RTA graph from ADCiso when there's an input signal. If there's no input signal, then the RTA display is totally blank. (where it should display the ADCiso's noise floor). Like some sort of a noise cancellation.
On windows, it can display the noise floor. This is not possible on my macbook.
Already unselected the ADCiso(record interface) as the system sound's microphone input, but still REW doesn't display the graph when there's no signal input feeding the ADCiso.
If I remove REW on microphone security and privacy settings, then REW cannot totally access the ADCiso, it can be selected as the input on REWs preferences, but the RTA graph won't display anything. (Even if there's a signal feeding the ADCiso) Obviously this access is required.
Yes, I also noted something strange when using my Cosmos ADC on my M3 MBP. There is sometime fishy going on with the mic setting and I got interruptions every second or so in the recording.... I didn't use REW but recorded sound to file.
So it isn't only REW.. someting has been changed and it must be MacOS.
I was also surprise to see the Mic thing in the top bar... perhaps time for a trouble report to Apple...
https://developer.apple.com/bug-reporting/
Did you check the MIDI Audio setting?
SylphAudio, I have no mac os PC and can't help you but so far nobody complained about Coasmos ADC+Mac performance being limited by 16bits or so.
PS: try to ask that in our discord channel, perhaps Mac users may help.
The former, the recording must be in sync with the digital source, if there is one, that is. At an integer multiple or fraction of the sample rate.What do you mean by sample-synched recording? In synch with the digital source? Or preseving the phase? What good would either do here?
Use cases there are many, basically every time you want to look way down into the noisefloor, especially in the time-domain.
Two practical examples:
https://www.audiosciencereview.com/...ve-sample-values-are-always-offset-by-1.6865/
https://www.audiosciencereview.com/...-hump-revisited-khadas-tone-board-v1-3.30136/
I think this is something recent and probably affiliated to some update of MacOS,,, well see what crops up...so far nobody complained about Coasmos ADC+Mac
Ok my bad, the default on audio midi settings is 16-bit 🤦♂️Yes, one need to make sure the settings in Audio Midi Setup for the device is what you want.... easy to miss...
So even when the sampling rate that's being selected on REW is higher, it's still selecting the specified sampling rate at 16bits.
Solved. Thanks for all your help
Yep. Same version of macOS.Is your Mac version Sonoma 14.4.1? Looks like REW can't get exclusive control over the ADCiso since the system treats the ADCiso as a microphone input (and it's applying noise cancellation). I already updated to the latest non-beta REW (5.31.1).
There's a new version of Sonoma that dropped yesterday, but I haven't installed on any of the Macs here yet. Yes, I am chicken.
Glad you found your solution!
After some questions and some research, here is my understanding of the situation with REW.
REW is written in Java. Keep that in mind for a minute.
Pavel Hofman wrote some specific drivers for REW that allow for Java to access the lower level interfaces to the audio hardware. They're the ones that have "EXCL" in the name. This provides for Exclusive Access (easy to read about on the web) to the devices, hence the name. This means that unless you disable the possibility of REW grabbing exclusive access to your devices, REW can change sample rates and stuff like that. These drivers are available for Windows and Linux. That's normally not available in Java.
At the moment, there are no equivalent drivers available for macOS. So, REW, written in Java, can't grab Exclusive Access to the Core Audio values and change sample rate settings and stuff like that. (Here's a great opportunity for you programmers out there...) That means that you have to use the Audio MIDI Settings app, which is the (very limited) user interface to Core Audio to set those values. Otherwise, you get sample rate conversions and bit reduction, depending on the settings and all that.
Hope that helps.
Hope that helps.
And thats the BS that Windows copied going from Win 7 to Win 8.
Plus- you can be assured of gettings sounds out (what the boss cares about). Minus- it will dumb down the interface to the lowest common denominator so on all platforms you need to check all the settings even when you think they are OK. I have spent days troubleshooting this stuff in Windows and Linux. its what it is.
Part of the issue is that there's way too many audio sub-systems built into these operating systems. They don't exactly complement each other, either.
Apple does a lot better by making sure there is a single system. Problem is, the documentation is poor from what I'm told and it generally is otherwise opaque. That causes a different level of challenges.
BTW, just keep telling yourself, "These are productivity tools. These are productivity tools...."
I was prompted to check out the Cosmos ADC with a 384 DAC. I used windows and Praxis (I very familiar with it) and got fine results at 1 KHz. However checking to be sure its really operating at 192K in this case at 68 KHz it was not right. It seems to be the FIIO KA which was making this strange 60 KHz + 68 KHz. So first I switched to the AP for 68 KHz and its clean so not the COSMOS then switch to the Breeze DAC (AKM) which was quite clean. Bill now has a 384KHz capable version of Praxis that I'll be trying tomorrow. It should be interesting.
Has anyone else seen this with ESS DAC chips?
- Vendor's Bazaar
- Cosmos APU a notch+LNA $70 to outperform APx555b for $30,000
