Hi Everyone,
I have a Adcom 585 power amp with the leaky caps (6x 220uF/25v) on the input boards. These have leaked all over the IC101 (Adcom 2A) and D111 to D114 (Adcom J2) section on the left channel. The spilled caps caused damaged to the IC101 and D113 components.
Anyway, Both input boards are thorough clean and all caps are replaced. Does anyone know what are the equivalent replacement parts for these IC101 (Adcom 2A) and D113 (Adcom J2) (this is 3 pins zener diode ???).
Please HELP....
Please HELP....
Hi Everyone,
Please HELP....
LM329DZ/NOPB from Newark is a J2 replacement
OP97FPZ from mouser for the IC101
Just an FYI. I've replace thousands of caps on mostly broadcast gear.
Dozens of times the acid from the caps ate through the copper traces leaving
an open circuit. The failures are so fine you won't see them on a visual inspection.
A real good idea is to Ohm out all the traces near the caps. Some of the traces I
had to 'splint' were sub 10 mil. Individual strands from old computer cables are
very fine and work well. Exacto knives, razor blades and flux pens are your friends.
G²
I'm also looking for those Parts. Adcom J2 and J6. My Board was fright very well. Also have to replace MPS-A13 and MPS-A63.
Any help would be Appreciated
DK
LM336Z-2.5/LFT7 is a replacement to the J6
OP97FPZ replacement to the IC101
LM329BZ a replacement for J2 or LM329DZ/NOPB
- ADCOM 585 Replacement Parts...PLEASE HELP!!!
