@motosapien
When you said you have no sound, were you testing one or both channels at a time?
Have you done the voltage checks on image 2 and 3 of ACA 1.6 build guide step 56?
Still not getting any sound. Perhaps it is my the new Emotiva pre. The only other thing is the resistance check on r 10. Using the 2M setting on my multi meter I got 0.32 on both when it says I should be getting 335k. The image shows this reading taken at the bottom of R10 and not at Q4 D?
https://d3t0tbmlie281e.cloudfront.net/igi/diyaudio/2FQWIEvDoExCO1FQ.large
- The diyAudio Store
- Amp Camp Amp Kit 1.6/1.8
