support
Have a second look on the ARTA homepage
http://www.fesb.hr/~mateljan/arta/support.htm
There is a new category
ARTA Release 1.01
ARTA Release 1.01 with al lot of new features is available now.
Have a look on Ivo's Homepage
http://www.fesb.hr/~mateljan/arta/download.htm
Heinrich
Heinrich
ARTA Release 1.0.3
Hi guys,
ARTA Release 1.0.3 is available now -->
Heinrich
Hi guys,
Heinrich
Re: PLOP
What is "DUT"?
Secondly, how is it possible that this very loud pop would not effect the measurement? Do I understand correctly that this pop is "normal"?
ente said:don't call it trouble
The plop ist just a little bit annoying but it makes no trouble to your DUT (if you be careful with the input signal)!
Heinrich
What is "DUT"?
New release
Hi guys,
ARTA release 1.1.0 is available on Ivo's homepage:
http://www.fesb.hr/~mateljan/arta/news.htm
Have fun with it
Heinrich
Hi guys,
Have fun with it
Heinrich
I've been using Arta with an m-audio 2496 internal sound card and via spdif with an external dac. Works very well indeed. Will download the latest version shortly.
I like this enough that I will purchase it as a replacement for Audiotester which on both of my systems is quite buggy.
ARTA 1.2
Delayed Xmas announcement.
In one or two weeks you can download ARTA 1.2. Here are some of the news:
ARTA
- CSD also as spectrogram
- directivity plot, new
- excess phase and excess group delay, update
- new IMD intermodulation distortion report (SMPTE, CCIF, DIN, IEC 60268-5), new
- new THD report
- max. impulse response sequence length extended to 256k (for reverberation time measurements in large rooms)
- reverberation time can be estimated in octave bands 62.5, 125,.. , 8000Hz
- output volume for multi sine extended to -30dB
- control of graph setup, update
- gate time can be shown as equivalent sound wave propagation distance in cm
- 192kHz sampling rate enabled
corrections of small bugs
- ascii file export of the step response
- correct swept-sine timing
LIMP
- optimized procedure for the estimation of TSP
Happy New Year
Heinrich
ARTA
- new THD report
LIMP
Happy New Year
Heinrich
I've been running the trial version of this for a few months now. I've got to say that its an excellent package that does all the important measurements with accuracy. Just in case you aren't familiar with what it can do here's the main attractions: Room, TS measurements, distortion, FR, phase, impedance, impulse and the list goes on and on.
The real bonus is that its so easy to use, with most measurements taking only seconds. This means more tweaking and less concentrating and messing around with software. Its also nice to see that its updated regularly with all the latest features.
I just bought it using the Share-it option on the ARTA webpage. I was amazed that it only cost £57, I was expecting it to be significantly more than that.
Whole heartedly recommended, probably the best measurement package out there - tons of power yet easy to use.
