Cabinets made with Finland Birch Plywood
My birch plywood speakers
I just finished my birch plywood monitors using a Dynaudio T330D and a Scan-speak 15wu8741.
It is an active monitor with a Hypex PSC2.400D plate amp(2 x 400 watt digital amps with a DSP) in the back.
All elements are CNC routed from one sheet of 30mm birch plywood and then glued together.
Just a few pics:
http://www.diyaudio.com/forums/attachment.php?attachmentid=273066&stc=1&d=1332334298
Just a few pics:
The cabinets are so beautiful. How about the sound performance?
Thanks for your pictures.
Hi Scott,
The price of the 300B mono block power amps is USD3,800/pair with our top quality double C-core output transformers. All the transformers including power transformers, output transformers and chokes are hand made by Kenneth, a experienced transformer engineer in Hong Kong. The output power of the 300B SE mono block power amp is 8W.
Thanks,
Tony.
Tony,
How much are those amps and how much power do they out out?
Scott
