Cambridge Audio 540A V1 Fault
Hey guys, hopefully I can get some advice on a fault with my CA 540A V1 Amplifier.
When plugged in I get one of a few things happening:
Often: Hum from power supply, nothing else.
Often: Single flash from standby light, click from relays, VERY occasionally protection light flash. Constant power hum.
VERY VERY occasionally: Unit boots and powers on. Works as normal, sounds great. A few hours/days later when left in standby the unit will cut out again and return to the previous two faults.
When plugged in even when not functioning it draws around 5W of power.
I have uploaded a few videos to try and show what happens:
VimeUhOh
VimeUhOh
I have a multimeter so I can fault find if someone tells me where to point the probes :)
I've had an offer of a repair from someone who knows what they're doing but I can't afford it at the moment as I'm out of work :/
Many thanks in advance
Matt
