Just use a trafo with 240V primary.
I guess if you buy the trafo in your country it has a 240V primary, evt. two 120V primaries.
If it has two 120V primaries you connect them in series to form one 240V primary.
Star grounding means that all ground connections are connected directly to the same point.
