Website is updated.
Dates are April 28, 29.
https://sites.google.com/site/indiyanaevent/
Hope you can make it!
Dear Mr Wolf: question about this rule (and any related):
I just happen to have a pair of the traditional type of 12" coax drivers and some CDs lying around that I might try to put into play, if allowed.
Would a a 12" coaxial driver with its CD tweeter would be acceptable under the rules? Isn't that a "large waveguide"??? Or are you not allowing those wierd "coax" drivers that have a separate waveguide sticking out from the woofer center?no large waveguides allowed, see faceplate rule. No large coaxial waveguides either, must be behind dustcaps if coaxial. Can only use waveguide if stock and fits within size criteria. If using a compression driver magnet must not exceed >5" diameter, and horn must comply with face sizes.
- Member Areas
- Clubs & Events
- InDIYana 2023 speaker DIY event...
