Lowther PM6A xFonken?
Hello Dave
Do you think a PM6C can work in these Onkens? I have an old unused pair aluminium coil 8 ohms, the cheapest one. The published specs are in attached pdf. I can check in Dayton WT3 WooferTester if it helps.
  • pm6c Al 8.pdf
I'm thinking to put this miniOnken in a wide tv stand, both sides a 50" monitor. 30L looks a very nice size for this.
But if you think it's worthwhile I can use a bigger box. Max volume around 50L and 70cm high.
Maybe is a better idea to keep dimensions and check PM6C in a enclosure that can be used with several Lowther drivers. LOnken? Lownken? ;)
Both options are ok for me.
Victor
The PM6A slver was a surprise. I am very pleased Jeff went ahead with this. The plans are available for others now. email me if interested.
dave
Dave, I emailed you about a week ago for the miniOnken plans for Lowther PM6A, Voxativ AC1.6, Tannoy HPD 385. I’m especially interested in these speakers that Jeff made.
Should I send you another email to request the plans? thanks!
