Well, after first not understanding why I had 5 volts out, unable to adjust it I understood after some investigating that I had grabbed a BC560C (PNP) and not a BC550C (NPN) for the positive board. I have now made some surgery and replaced it. But with a 3K9 and 1 K trim I only come down to 17,7 volts so it seems like the K117 there is mighty strong. I guess I have to go down some steps in resistor value. Any steps I can take to smartly calculate what the values should be before I start guessing?
Of course I started guessing and put a 10K over the 3K9, making it a 2K8. I can now trim between 14,06 to 17,36 volts with 1 K trim (or 980 something). The measured value for 15 volts is 3K07. I have 200 and 500 ohms trimmers in my box and 2K7 and 3K metal film standard cheap resistors. It would be preferable for ppm and drift with a smallish trim and low ppm resistor. Would I be to daring to order some low ppm 3K resistors and put 200 ohm trim in?
Measured K117:
Q102 3,63
Q103 4,22
Q105 4,87
Measured K117:
Q102 3,63
Q103 4,22
Q105 4,87
Simply by Vdrop on the 3k9 and Ohm's law I=V/R you know what mA run in the Vref by the Jfet. From there you remove as much I*R value as much voltage created you wanted to get rid off.But with a 3K9 and 1 K trim I only come down to 17,7 volts so it seems like the K117 there is mighty strong. I guess I have to go down some steps in resistor value. Any steps I can take to smartly calculate what the values should be before I start guessing?
Hmm some European made type I would guess. Looking not as old ABBA but maybe as old as A-haI wonder what those resistors could be? Measures straight with DER EE
Ace of Base were from your part of lands I think?A-ha is Norwegian, not over my doorstep
Yes. They were part of what is refered to as ”The Swedish Pop Wonder” I beleave. Well known markers of history.
https://sweden.se/culture/arts-design/the-swedish-music-miracle
Neg reg coming up in a bit!
This one came up on first kick and without smoke. They are both a little lean on current, the positive took 203. Rethink R101/201 I think.
I used 2K7 + 1 K this time, can trim between 13,73 to 17.00. 15 v happens at 3,059 ohm since I used similar values on k170 between boards.
- Power Supplies
- SSLV1.1 builds & fairy tales
