Transformer for 1626 Darling Amp Question
B+ for the Darling is around 265V.
Any transformer supplying 150mA or more is sufficient in the current department.
The Darling schematic uses a voltage doubler to arrive at abovementioned b+.
There are more ways than one to skin a cat. But if you want to build it exactly as Bob did it...you should indeed get a 200VAC winding. If it does not have a 12,6vac winding ( which most don't have) you could get a seperate transformer for that.
Reactions: 1 users
