You're upto something the short way - dead end most often.Maybe better?
I can't agree 100% with that. If you need a zero impedance output, then this is a solution.Yes, as in post #5. Resistors within the nfb loop are not helpful.
"Mother's little helper", but without -3dB noise attenuation. ;-)I would suggest this:
- Analog Line Level
- Valid opamp circuit?
