Go Back   Home > Forums > General Interest > diyAudio.com Articles
Old 21st October 2016, 04:45 AM
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
Default A manifesto for Audio DIY-ers
Edward T Dell (†)
Jan Didden
The title for this essay is borrowed from an Editorial that appeared in The Audio Amateur (now AudioXpress) some 30 years ago. It’s Owner, Publisher and Editor was Edward T Dell, a man who...
19th December 2016
EFU1944
Lovely article. You have described the typical Diy' it perfectly.
27th December 2016
Duck-Twacy
Shoot, I am a tinkerer...
Although I finished and used at least 20% of my projects
Is that all there is?
1st February 2017
BasicHIFI1
Jan, thanks for a very encouraging article. I thought I was the only one with unfinished projects!
First: believe that you can do the job. Despite the momentary setback, be sure you are going to come through this eventually. Never give in to the idea you are too uninformed, or stupid, to solve the problem sooner or later. It has an answer and you can find it
Lots of encouragement here!
Copyright ©1999-2017 diyAudio
