2N3055 inside - commercial famous amplifier models, quasi complementary power output
The 2N3055 power transistor was introduced by the Radio Corporation of America (RCA) in the early 1960s. It was one of the first silicon power transistors, offered unrivalled second breakdown immunity and found many applications particularly in audio power amplifiers.
Under
http://www.diyaudio.com/forums/solid-state/10337-amplifier-based-2n3055.html
there is a circuit collection
check out also this thread:
https://www.diyaudio.com/community/threads/2n3055-the-early-years.382690/
early advertisement is on page 67 under
https://worldradiohistory.com/UK/Industrial-Electronics/60s/Industrial-Electronics-1965-01.pdf
(this page I have upload here on page 26 in post #505).
and last page (page 64, feb. 1964) under
https://worldradiohistory.com/Archive-Electronics/60s/64/Electronics-1964-02-28.pdf
(this page I have upload in post #518)
I want to have a bunch of such commercial famous power amplifier models and UK/US brand names made in the 1960s (only with quasi complementary output stages).
Thank you very much for your hints.
here very fine sounded receiver with 2N3055 as power devices:
Braun series "Regie"
Reactions: 1 user
It was 225WRMS, they no longer do it.
Shame it was a good solid amp.
I am sure i have seen a picture of it on this forum at some time.
I remember it though i never bought one ;)
It used MJ2955 as the pnp compliments & a +/-55V approximately power supply. Lord knows how it didn't blow up as you can see the rail voltages were well in excess of the VCE of both the 2N3055 & the MJ2955. I guess they were relying on the reverse biasing of the output transistors to stop them exploding :D
60V transistor, 110V PSU :eek:
Reactions: 1 users
The CM Labs 911 was among the very first commercially built solid state amps that made the unheard of power output of 100wRMS. It is a quasi complementary output stage with a big cap blocking DC. Nice amp actually.
The other amp of the day, that was also quasi complementary was of course the Dyna ST-120.
There really were not a lot of powerful solid state amps before 1970.
_-_-bear
Can't believe nobody's mentioned the Quad 303 yet!
NAD3020 used 2n3055s as well, but I think that was in the late 70s.
Sadly, when manufactures switched the 2n3055 to epitaxial, the 2'nd breakdown immunity went out the window.
edit: oops, maybe the NAD wasn't quasi? I can't remember.
Reactions: 1 user
