The Hundred-Buck Amp Challenge
UPDATE:
Since this thread had pretty much run its course, the rules were loosened in early 2016:
Nobody is enforcing the rules any more. This thread was about making a playable guitar amp for a budget of $100. Unless anybody cares, maybe it should now be about an amp you would really want to use for minimum $$$$. Several good ideas were spawned here and a few amps were made. How many of those amps still get used?
Back then, several compromises were made in our designs to fit the budget. Now that we aren't constrained, we can use the parts we like to get the tone we want...Bring on the 12AX7's and the real OPT's, if that's what works. Anyone and everyone is welcome to play along...rules, we ain't got no stinkin rules!
Try to keep the drama to a minimum.....We all realize that not everybody had the same definition of "tube amp". So what! If you don't like my amp, don't build one. If you have a better idea, post it!
tubelab.com
This challenge was spun off from another thread here: http://www.diyaudio.com/forums/tubes-valves/190449-need-recommendations-diy-small-guitar-amp.html
The challenge is to build a low-powered practice amp for electric guitar. Power output should be in the range of 2-5 watts. The amplifier project need not include a cabinet or speaker.
Total cost of the completed amplifier is not to exceed US $100 ( or equivalent value in non-US currency).
The power supply section can be solid state, but the signal stages must be all tube. Semiconductors may be used for biasing, current control, etc.
The amplifier must be reasonably safe. No line-powered (non-isolated) designs will be considered, and proper enclosure of high-voltage circuitry is required.
Parts may be sourced from any outlet available to the general public; the object is to develop an amp that anyone can build in the months to come.
Parts from vendors who have severely limited supplies or short-term discount pricing should not be used.
Suggestions for additions or limitations to the challenge rules will be entertained until June 20th, 2011. At that time, the rules will be 'carved in stone', and added to this thread.
A poll will posted, and challenge participants will be asked to vote on the design they consider best overall. On August 15th, 2011 the winner of the design poll will have the cost of all materials for his/her amplifier reimbursed, up to the amount of $100. In addition, $250 will be donated to diyaudio.com in appreciation for providing this forum.
I think this is going to be a whole lot of fun...
how about this one? a 5F1 wannbe:D
i got the 2 x 12LW6 tubes for a $1 each at rogalski's...
the 12AX7 cost P350 or about $7.90
the irons, a power traffo, a single ended opt, 4k:8ohm, and a choke for about P2500 or about $56....
easily less than a hundred green ones....:D
How about using a Compactron?
Sure! Lots of interesting multi-section combinations in these envelopes:
Compactron Tubes: A Junkbox Guide
Or how about space-charge tubes, as used in auto radios of the '50s and '60s:Space Charge and Other Low-Voltage Tubes
Or tubes with higher-than-normal heater voltage, whose filaments might also serve to provide a bias reference... Or familiar pentodes hiding in bottles with different pin-outs and heater voltages, e.g. 16GK6...
There are hundreds of possibilities; the combination just needs to be easily duplicated by anyone who decides to build your design.
Here's another tip for cutting costs without compromising performance. A linear pot can easily be converted to an audio-taper pot by simply bridging its terminals with a 1% resistor. I use this trick all the time to save five bucks or more on volume controls.
Find a 50-cent military-surplus linear pot, add a 50-cent high-quality resistor, and for a dollar you have a pot which will equal or better many "boutique" audio-taper log pots. Here are a couple of articles which explain how:
About halfway through this article: http://www.geofex.com/Article_Folders/potsecrets/potscret.htm
...or the first section of this one: ESP - A Better Volume Control
Why not?
Too bad I can't find one of my "Turbo Champs" (sold the last one 10 years ago). They were quite popular and really screamed. Schematic enclosed. Probably over $100 at todays prices, but swap the KT88 for something cheap like a Chinese 6L6GC
Hey, bst, you wanna make something and play guitar, or count the pennies spent in each resistor?
Anyone can go down to Sam Ash (Music store chain) and plop down their credit card and walk out with a Marshall stack. It would a challenge to make a good sounding guitar amp for less than $100. Yes it is possible to spend more than $100 on the speaker, and that is a big part of the sound, but we aren't counting speaker $$$$.
Now I'm dissapointed. I'm not one to turn things down.
How about something you (or another guitar player) would want for themselves.
I am planning to dig out as many old breadboard as i can find wire stuff together until I get a sound that I would keep. It's got to be something new and unique. I don't need another "Champ".
I agree, though champs are nice home use platforms, and many sound great, they have been beat to death in variations.
Maybe reverb should be mandatory LOL
Mod Tank from CE 4AB3C1B, 8 ohm input, 2,250 ohm output, long delay.
That should get rid of the dryness anyway :D
Sounds fun! Do you have any guidelines for the "prize"? Should this be a winning design for under $100 that is useful and buildable by others? If so, you might want to specify that the parts should be available to most people for a price that keeps it at or under the $100 (USD, right?).
In most loudspeaker DIY design contests, for example, the drivers and crossover parts need to be in stock somewhere for at least a while (even if they are surplus), not one-off custom units, out of stock clearance leftovers, or unobtainium. If someone builds with junkbox parts on hand, the equivalent purchase price is still figured into the cost for the purpose of the design and the contest. The cabinet (in this case, the chassis as well) is not figured into the cost since there can be so much variation. Switches and pots would be priced for a common part.
Last year our little group ran a similar competition for a 6V6 amp (stereo) housed in a container that came from Ikea.
6V6 Competition
Photos and some schematics can be seen at 6V6 Entries
The constraints are what make the competition interesting. It's not that easy to stay under the $$ limit. Another resistor here and another cap there and soon you are hitting the $$ limit. We really like the idea of using non traditional containers. I wandered around Ikea a few times before I found my container. You can read about my entry here.
6V6 Lumiere
This year we are doing a similar competition for an under $100 line stage based on Russian tubes. The container has to come from Target.
Bottleneck Linestage Competition and Audio Meet - June 18
You can read about my entries here.
Russian Line Stage
The auditioning part of the competition will be this Saturday, so if you are in the DC area you are welcome to attend.
ray
What would be really fun would be to set an agreed OP traffo, so the different circuits could be tested without duplicating the expensive part of the build.
I think finding a creative source for OPT's that really aren't OPT's will be one of the deciding factors in the success of the design. It is also a big factor in the "tone" of a guitar amp. Much of Fender's tone comes from using tiny cheap OPT's, while Marshall used rather big transformers. Choosing the OPT up front restricts the tonal possibilities.
I for one will be exploring push pull amps while I am assuming most builders are going SE.
All parts should be something that anyone could order, and the total price should add up to less than $100 USD, right?
I would even go as far as that an equivalent part must be orderable from somewhere in the world and that price should count. I am sure that I could build a 100 watt flame throwing guitar amp head without buying a single part, with mostly free or cheap stuff. That wouldn't be fair to the guy that isn't a compulsive junk collector like me.
Wow. Competing against Tubelab and Wavebourn, two heavyweights. I'm chickening out!
The one thing about guitar amps is that the "winning sound" is far more subjective than any HiFi, tube VS SS, full range VS 3 way speaker debate that has been seen on this or any other forum. If the judges are chosen from guitar players, and non guitar players, (a jury of our peers / members) everyone will have a good chance of winning. Besides, I will bet that Trout has made more guitar amps than Wavebourn and Tubelab combined. He knows how to play guitar too.
I think you will need to set some required low frequency response (maybe 40 Hz for guitar?), or the amp/OT will just be a tweeter amp. Real easy to do a 400 Hz and up amp. (use air core even) Similarly the HF end needs some minimum, or the amp will be 1000 Hz limited. And the Watt limit should be taken as a minimum, since its easy to get a couple of $1 sweep tubes to do 50 Watts in P-P. And cheap 480 V industrial/control transformers off Ebay are usually a few hundred Watts at least.
Many guitar amps use the venerable 12AX7. The 12AU7 and the 12AT7 are also common. The only common output tubes that will fit this price and power ranges are the 6AQ5, the 6BQ5 / EL84, the 6CW5, and maybe a Chinese EL34 or 6L6GC. Since these tubes can be found for an extremely wide price spread we could agree on a fixed number for these tubes up front.
The reason that I propose this is the 12AX7 is the defacto standard in guitar amp gain stages. It is available world wide. There are dozens of cheap stand-ins from the TV and FM radio tuner tube selection, but their use immediately limits the target audience because a lot of these are not common outside the US. The ones that are common will skyrocket in price as soon as the winning design gets published.
The output tube choice gets a bit more sticky since the common guitar amp tubes are just too expensive and not really suited to low power / low voltage operation.
If cheap oddball tubes are used, there should be multiple choices, or thousands in stock somewhere to insure a stable supply. Look at what happened when Pete Millett published his red board amp. The 6GV5 was on the dollar menu at 2 different suppliers. Now they are $5 if you can find any.
But if i create an OPT with steel I cut out of soda-cans, do I have to count the price of the soda cans?
In this part of the world most cans are made of aluminum.
