Pictures of your diy Pass amplifier
Whoah... stunning builds. Impressive.
My 4 DIY builds. Thanks Nelson Pass
Reactions: 4 users
ACA monoblocks using CPU coolers for heat sinking, each output device attached to its own 'tower' - Installed global rheostat for adjusting fan speed.
Reactions: 17 users
Joined 2008
I decided to try full active DSP again on my 3-way OB speakers today. More amps in service! :spin:
  • Bass - IcePower 300A2 in classic Hitachi chassis
  • Mid - Pass F5m (with outboard power supply)
  • High - Pass ACA Mini
Sounds very good after many PEQ tweaks.
Only down side: Iron Pre sitting idle for the moment. :cuss:
Reactions: 3 users
Hello all
Is it not too late to build my own Aleph P?
Just finish it, I make it dual mono with 256 steps relay volume control by my own coding controler and I also need remote control for the preamp.
All PCB and chassis is my own design. chassis is devided in 2 partitions one for audio section and the other for the noisy part. let pictures told other things.
Hope Aleph P is not obsolete for this board.:p
  • Thank You
Reactions: 30 users
