Avatar doesn't size correctly
frugal-phile™
Joined 2001
I went thru a bunch of experiments, IIRC i ended up uploading a 400x400 pixel image.
But looking at the image used by XF it is 384x384 pixels. XF doesn’t do a great job at resampling.
Note that Preamp could have a much cleared avatar if he uploads a larger picture (his is 192x192). Jans as well.
dave
AX tech editor
Joined 2002
This is the image I'd like to use.
Jan
stv
Joined 2005
If your avatar is not square the forum-software will crop the longer sides to fit the shorter side. Just fill in white or black or any background above and below (or your old avatar that i liked very much) to get square 1:1 ratio and put the new one in the middle.
let me know if you want me to do it.
