Rockford Power T1000-4AD
This unit has one damaged channel. U1 is a IRS20124S. Is there something else I can use without needing to replace them in every channel? Also, D32 has JS written on it. Not sure what that part is. Q21 says 2Q and Q22 says W1A? I have to go out but will try to look up the 3 in the code book later or tomorrow. Biggest issue currently is the IRS20124S. I got the output transistors.
Thanks in advance!
Pics coming in a minute :)
Good afternoon Perry.
I believe the class AD "output card" is just signal stuff??... Please see 1st pic. I can remove 1 from the board if you'd like a nice picture of the card.
I believe the output section is the 2nd picture. That's where all my damage occurred.
