Hi Bart,
I'm also looking for replacing tubes on my Stax SRM-007Ta and I wonder if you've managed to find some information on that...?
I think there is an option to replace original 6FQ7/6CG7 tubes with 6S4A tubes, but that will require rewiring and soldering work, for which some schematics and instructions will be needed.
Please advise,
Sasa
Please advise,
Sasa
Hi Sasa,
6FQ7/6CG7 are popular tubes, so no reason to use something else. A 6S4A is a single triode with different characteristics so you're looking at more than rewiring sockets. Then you'd have to redesign the circuit for the other characteristics.
Just use the intended tubes. Many audio amplifiers use them.
-Chris
-Chris
Thanks for a straightforward reply, Chris.
I'm new user of both Stax headphones (or "earspeakers") and Stax amp (or "energiser"), which is also my first tube-based audio equipment.
The main reason I asked about tube replacement is that, in order to have decent sound levels on my Stax 009 headphones, I have to adjust level on my Stax SRM-007Ta amp with 6FQ7/6CG7 tubes pretty high (around 8-9 out of 10, with the pre-amp also around the same level), and that the existing tubes are reaching the end of their lifetime.
I don't know if new tubes will provide better output levels, but I'm willing to try -- may I ask, if you know, or have some experience, which of 6FQ7/6CG7 type tube manufacturers you would recommend to buy from, particularly regarding their voltage handling performance?
Thanks again and best regards,
Sasa
Sasa
Thanks for confirming what Chris suggested, Bart -- yes, I'm using balanced inputs with balanced input signals (from Quad Artera Solus, connected via balanced Linn XLR cables). What is your SRM-007 & headphones set-up, and do you need to adjust higher volume levels on pre-amp and/or Stax amp?
Also, following my question to Chris, which brand/type of tubes you may recommend (or you may have already used?) for replacing the original ones...?
Sasa
Sasa
Here's (part of) the schematic. What other information do you need?
The "output level" is determined by the gain of the amplifier, which in turn is controlled largely by the amount of global negative feedback. The gain parameter of the tubes does not make a huge difference. If your tubes are worn out, replace them with the intended type.
The max. volume of the "smaller" Stax amps is limited by the power supply voltage and the dissipation limit of the tubes. There are no simple tweaks to change that.
I would recommend any new manufacture tube sold by New Sensor. Excellent quality, very consistent tubes. Electroharmonix would be my first choice, although they are all made extremely well from the Reflector factory in Russia.
Low level could also be due to low DC charge voltages. Electrostatics are not efficient either. So if they are truly low in level, have the power supply checked before messing around with anything else.
As for input type. Balanced inputs are normally adapters. Electronic or transformer (each have drawbacks). Most equipment is single ended internally. Balanced connections are for low level signals travelling over distance. Something you want to avoid in the first place. A balanced connection can never be lower distortion than single ended, and may be 1.414 x as noisy as single ended. Now if the designer messed up the design, balanced may be better, but the entire design would be suspect in that case.
- Headphone Systems
- Schematic STAX SRM 007 T MK2
