His Master's Noise: A Thoroughly Modern Tube Phono Preamp
After more than 25 years of faithful service, it seemed that it might be time to redo my phono system. After all, I like to think that I've picked up a few tricks in the intervening years... The old system consisted of a VPI HW17-II, a Linn Ittok LVII tonearm, and a Troika cartridge. The Troika was...
SY
I'm finishing up an article on a tone control line amp- once that's done, I'll write up my MM amp. Until then, you can turn this into a very good MM preamp if your cartridge is tolerant of capacitance (e.g., Grado): just eliminate the input transformer and change the first stage grid resistor from 6k8 to 47k. If your cartridge needs a low input C (e.g., the Audio-Technica 150MLX that I use), my upcoming MM-only design will take care of that.
