His Master's Noise: A Thoroughly Modern Tube Phono Preamp
After more than 25 years of faithful service, it seemed that it might be time to redo my phono system. After all, I like to think that I've picked up a few tricks in the intervening years... The old system consisted of a VPI HW17-II, a Linn Ittok LVII tonearm, and a Troika cartridge. The Troika was...
I'm struggling to find suitable connectors to get between the psu and phono stage.
I obviously want to make sure that the psu can't have exposed pins with HT on them if not connected.
I did find a 5 pole connector that looked OK but as it had a plastic body I couldn't connect protective earth through that. At least that's what it looks like sy did in the pictures.
The 6 pole version isn't stocked any more.
I don't know how I feel about having a 5 pole cord and then a totally separate earth bond wire connected by screw down binding posts. I would use the crimp type connector that looks like an earth tag that goes over the bolt that gets screwed down so it can only come off it the nut comes completely off too.
