Audio Component Grounding and Interconnection
This article focuses on audio system design for the DIY enthusiast implementing a stereo system for home use. There is a lot of information available for designing audio circuits, but precious little on interconnecting those circuits into a total audio system to achieve maximum performance....
if Reinforced/Double insulated mains xfmr, internal wiring is followed there should be complete freedom in what to do with metallic cases and outlet protective earth
further in Intrinsically Safe circuit design which keeps chemical plants from exploding diodes used within their continuous ratings are only assumed to fail shorted - with 2 redundant paths 2 cross connected bridge rectifiers would be accepted in this much stricter safety standard as an "infallible" connection for safety analysis
