What is Gain Structure?
Gain structure (AKA Gain Staging) is a concept that gets talked about a lot in pro audio, but most home audio folks have never heard of it. Understanding gain structure can help you get the cleanest signal possible out of your system and avoid some nasty things. Things like noise and clipping,...
Many thanks for the help!
Andrea Ciuffoli (thanks)
I went to his site and found his paper on his
"Power Follower 99" a solid state class A amp 30wps at 6ohms
He also says
"The presented topology, has NO gain (actually it looses something) and should be preceded by voltage gain stage, with an output swing not lower than 10Vrms and Rout < 1000Ohm. "
This sounds perfect! Can this zero gain amp be implemented DIY or is it too esoteric and should be purchased from a person like Ciuffoli?
