Go Back   Home > Forums > Blogs > My DIY projects
I returned to DIY electronics in 2009 after a 20 year pause by building a few kits to get in shape. This blog is for me to keep track of my progress.
Tube power amps
Old
Velleman K4040 mods
Posted 8th May 2011 at 12:32 AM by alexcp (My DIY projects)
Updated 4th May 2014 at 12:59 AM by alexcp
I posted some time ago a note about my Velleman K4040 amplifier. The sound of the amp as built from the kit was unremarkable and definitely not in line with the price. Lacking experience with tubes, I was looking for some time for well documented mods to the kit.
I found two 2006 posts here and here and implemented them rather directly. The only difference is that I used IXCP10M45S instead of a pair of J508 current sources in each channel and replaced the 1N5408 rectifiers with UF5408 instead of adding noise suppressing capacitors in parallel to them.
The mods did not leave much of the original Velleman design in place; the result, however, is a remarkable improvement in sound!
However, two problems remain: (1) I got hum that wasn't present before the mods; and (2) a two-year old running around doesn't get along with eight hot, attractively glowing tubes. The project is shelved until a better time.
For future reference: The toroidal...
Click image for larger version
alexcp's Avatar
Posted in Tube power amps
Views 6034 Comments 3 alexcp is offline
Old
DCPP aka Engineer's Amplifier
Posted 8th January 2011 at 02:09 AM by alexcp (My DIY projects)
I just built a Distortion Cancelling Push Pull (DCPP) amplifier designed by Peter Millett. It sounds very nice, was fairly easy to build, and is rather inexpensive. Thank you Peter for the great design!
ID:	308   Click image for larger version
ID:	309   Click image for larger version
alexcp's Avatar
Views 2729 Comments 0 alexcp is offline
Old
Elekit TU-879S
Posted 12th August 2010 at 07:24 PM by alexcp (My DIY projects)
Updated 11th April 2016 at 07:59 PM by alexcp
Elekit TU-879S is the best sounding kit I have ever built. Thank you TubeDepot.com for selling these kits. With my DIY full range speakers I mentioned a couple of posts earlier, the sound is fantastic.
Update: one of the original 6L6 tubes got blue sparks inside. As this amp can use KT88, KT66, or EL34 without any adjustment or modification, I replaced both 6L6s with EL34s left from the K4040 project, but the sound deteriorated. A replacement 6L6 from TubeDepot.com restored everything.
alexcp's Avatar
Views 3090 Comments 2 alexcp is offline
Old
Velleman K4040
Posted 12th August 2010 at 04:53 PM by alexcp (My DIY projects)
Updated 11th April 2016 at 07:45 PM by alexcp
Then was the K4040 from Velleman. Contrary to some reviews, I found this amp sounding rather nice, particularly after I replaced the EL34 tubes in the output stage with separately purchased matched quads. However, the sound does not quite match the price, and I keep this amp mostly for its looks.
Update: I modified this amplifier, leaving little of the original design. See a later post with the details.
ID:	241   Click image for larger version
alexcp's Avatar
Views 5762 Comments 0 alexcp is offline
Old
S5 Electronics "L" series tube amps
Posted 12th August 2010 at 04:52 PM by alexcp (My DIY projects)
Updated 5th May 2015 at 12:38 PM by alexcp
I started with a Model 8LS stereo amp from S5 electronics. Later I put it into a Hammond enclosure and replaced the tranformers with Edcors.
Separately, I built a Model 16LS, which is the same thing with a doubled output stage, giving a very similar sound. Both use a 5670 double triode in the voltage amplifier and phase splitter, and 2x6005 (4x for the 16LS) in the PP output stage.
Both versions are very easy to build, nice with vocals, but not quite HiFi - see the FFT charts. Matching tubes and the resistors in the split-load phase splitter circuit helps to reduce distortion.
ID:	439   Click image for larger version
ID:	440   Click image for larger version
ID:	441   Click image for larger version
ID:	442   Click image for larger version
ID:	444   Click image for larger version
ID:	1618   Click image for larger version
Name:	K-16LS two-tone.png
alexcp's Avatar
Views 2633 Comments 2 alexcp is offline
Copyright ©1999-2017 diyAudio
