Active Group Buys
Instructions for this page
Instructions for this page: Write the newest group buy at the top. Write status (Open/Delivering/Closed) and the start date. Make a very short description of the offer.
How to create a new group buy page from the template?
Click EDIT at the top (not at the right) of this page, not at the right!
Copy the text from a present group buy (below in this page)
Change the text in the heading and in the description. Change also the link name to something appropriate. Try to have a similar naming as before.
Click on PREVIEW and check that it looks like expected.
Save the page (this page).
Click at the new and empty link you just have created.
Click at EDIT for this new page.
Make a new window in your browser.
Search for the group buy template, click at EDIT at the top and choose CTRL-A (CMD-A for Mac users) to select the whole content. Choose CTRL-C (CMD-C for Mac users) and copy all.
Paste this content into the new page you have created.
Save the page first so you at least have one copy of it.
Click at EDIT on the top of your new page and change the text so it will fit your needs. Don't forget to PREVIEW often.
SSR03 Super Regulator Power Supply (Aug 2014 Closed)
An ultra stable regulated dual power supply with super regulators
Click here to sign up
SSB01 Ultra High performance diamond buffer (Nov 2013 Closed)
A SMD Ultra High performance diamond buffer built on a 4-layer pcb
AF-4 Active Filter Board (Oct 2011 Closed)
Active Filter board repeat buy. One channel HP/LP/BP and EQ, LT, Phase
SST03 Soft start for toroidal transformers (Mar 2011 CLOSED)
A soft start for devices with high inrush currents such as amplifiers with toroidal transformers.
QRV09 Ultra High Performance Headphone Amplifier (Mar 2011 CLOSED)
A headphone amp based on TPA6120a and with surface mounted parts
Peter Daniel's AJ-X PCBs - 3rd GB (Dec 2010 CLOSED)
ADP05 SO08 to DIL08 adapter (May 2010 Closed)
Leach amp clone + extension board (Apr 2010 CLOSED)
Leach Amp clone, pcb design by Jens Rasmussen.
Peter Daniels AJ-X PCBs - 2nd GB (Jan 2010 Closed)
RFB03 Rectifier bridge pcb (Jan 2010 CLOSED)
Ikoflexer discrete shunt regulator (December 2009 CLOSED)
alexw88 PA150, BPA300 project together with DRV134 pcb (Nov 2009 Closed)
The PA150 pcb is a power amp based on 3 pcs. LM3886, design by alexw88
This page has been seen 6,489 times.
Created by onLast updated by on
