diyAB Amp, aka. The Honey Badger
Name | diyAB Amp, aka. The Honey Badger |
Type | Solid state |
Application | Driving loudspeakers |
Class | A/B |
Approx Cost | it depends |
Designer | ostripper |
Thread | main thread and build thread and discussion of diyAudio Store boards |
The Project
The first Class AB power amplifier to be featured at the diyAudio Store. It has been designed from the ground up with the sonic character, power output and most of all the DIYer in mind. With a basic power output of 150W at 8 ohms, this power amp is sure to have a place in every builder’s projects list. Not to mention its flexibility and adaptability to work with most output devices available locally in wherever country you may be.
Schematic/Blueprint
Bill of Materials
mbrennwa Jan-2017
These part values are based on the build guide for version V2.0, the version V2.4 schematic, and a few small modifications as described in the comments.
Part | Value / Description | Comments |
Transistors | ||
Q1, Q2 | SS9014 | |
Q3, Q4, Q7, Q8 | KSC1845 | |
Q5, Q6, Q9 | KSA992 | |
Q10 | MJE350 | |
Q11, Q12, Q13 | MJE340 | |
Q14 | MJE15032 | |
Q15 | MJE15033 | |
Q16, Q17, Q18 | MJL4281 | Higher SOA than standard choice in build guide |
Q19, Q20, Q21 | MJL4302 | Higher SOA than standard choice in build guide |
Diodes | ||
D1, D2 | 1N914 | |
D3 (Cascode voltage reference) | 1N4744A | Omit R18 and replace it with Zener diode (D3), use jumper “C-Z” (cascode / current mirror) |
D4, D5, D8, D9 | 1N5408 | |
D6 | LED red 3mm | |
D7 | LED blue 3mm | |
BAKER CLAMP “D-BC” DIODE | BAV21 | |
Resistors | ||
R1, R52 | 100 kΩ / 0.25 W | |
R2, R5, R22, R24 | 820 Ω / 0.25 W | |
R3, R6 | 22 kΩ / 0.25 W | 22 kΩ for lower overall gain (more feedback): gain = 1+(R6/R5) = 27.8 *** measured (150 Hz sine): V-in = 0.342 VAC, V-out =9.1 VAC ==> gain = 9.1/0.342 = 26.6 |
R4 | 4.7 Ω / 0.25 W | |
R7 | 200 Ω multi turn trimmer | |
R8, R9, R15, R16, R26 | 100 Ω / 0.25 W | |
R10 | 22 Ω / 0.25 W | |
R11 | 10 kΩ / 0.25 W | |
R12 | 10 kΩ / 0.25 W | |
R13 | 15 kΩ / 0.25 W | |
R14, R28 | 2.2 kΩ / 0.25 W | |
R17 | 1 kΩ multi turn trimmer | |
R51 | 22 kΩ / 0.25 W | |
R19 | 68 kΩ / 0.25 W | |
R20, R21, R25 | 220 Ω / 0.25 W | |
R23 | 47 Ω / 0.25 W | |
R24 | 1.5 kΩ / 0.25 W | |
R26 | 10 Ω / 0.25 W | |
R27 | 51 Ω / 0.25 W | For approx. 10 mA current in “big” CCS |
R29 | 680 Ω / 0.25 W | |
R30 | 500 Ω multi turn trimmer | |
R31 | 15 Ω / 0.25 W | |
R32, R33, R34, R35 | 22 Ω / 0.5 W | |
R53, R54 | 22 Ω / 0.5 W | |
R36 | 150 Ω / 1 W | |
R37, R38, R39, R40, R41, R42 | 2.2 Ω / 0.5 or 1 W | |
R43, R44, R45, R46, R47, R48 | 0.22 Ω / 3 or 5 W | KOA Speer seem to be the same thing as KIWAME |
R49, R50 | 10 Ω / 3 W | |
Capacitors | ||
C1 | MKP, 4.7 µF / 35–50V | Audio input capacitor |
C2 | Silver Mica, 270pf / 50V - 100V | |
C3, C10, C12, C14, C16, C21 | MKP, 100nf / 63V – 100V (C21: 250V) | C3: bypass for C4 |
C4 | Non-Polar Electrolytic , 220uf / 50V – 100V | Feedback loop |
C5 | Electrolytic, 100 µF / 63V - 100V | |
C6 | Film, 220nf / 35V - 50V | |
C7 | Silver Mica, 100pf / 300V - 500V | |
C8 | Silver Mica, 470pf / 300V - 500V | |
C9 | Electrolytic, 22uf / 35V - 50V | |
C11, C15 | Electrolytic, 220uf / 63V - 100V | |
C13, C17 | Electrolytic, 470uf - 1000uf / 63V – 100V | |
C18, C19 | Silver Mica, 47pf / 300V - 500V | |
C20 | Film, 680nf - 2.2uf / 100V | |
LC Cap | Silver Mica, 5pf / 300V - 500V | Don't install the LC cap, the amp sounds better without it |
Power Supply
The Honey Badger will work with rail voltages from +/-30VDC to +/-70VDC (see http://www.diyaudio.com/forums/solid-state/211905-diyab-amp-honey-badger-build-thread-102.html#post3873478). The build guide describes a linear power supply with +/-63VDC rails using a 800VA transformer with 45-0-45 VAC secondaries. Recommended capacitance is a total of 40'000 µf per rail.
Simulations and Analysis
Construction (Steps / Tips / Notes)
There are a number of options to consider when building the Honey Badger amp. First of all, read the build guide, which has a thorough description of most options.
This post also has some useful comments: http://www.diyaudio.com/forums/solid-state/211905-diyab-amp-honey-badger-build-thread-48.html#post3598622
Project Modifications
Modification 1
Modification 2
