SpeakerProjectTemplate
Name | <Project/Speaker Name> |
Type | <Subwoofer, Dipole, Multi, Electostatic etc> |
Application | <PA, Reference, waking the neighbors...> |
Speaker Count | <1-1,00,000> |
Approx Cost | 100,000,000 GBP |
Designer | <Original Designer> |
Thread | <URL to the discussion thread> |
The Project
Introduction
Give a brief [1-2 paragraph] description of your speaker design, possibly including what inspired your design.
Goals
What were some of your goals with the design of the speakers? In the end, did you achieve them? If not, where did the design fall short of your expectations?
examples: I wanted to create a speaker with perfect tonality but ended up with something that sounded like it plays under water.
Specifications
Name | Description |
Freq Range | <eg -6dB at 27Hz and 33kHz> |
Freq Response | <eg 34Hz 28kHz ±3dB on reference axis> |
Dispersion | <eg - Within 6db of reference response> |
Horizontal | <eg - 60 degree arc> |
Vertical | <eg - 10 degree arc> |
Sensitivity | <eg - 90dB spl (2.8V, 1m)> |
Harmonic Distortion | %THD or plot |
Nominal Impedance | <eg - 8 Ohm, min 2Ohms> |
Crossover Points | <eg - 300Hz, 4KHz> |
Power Handling | <eg 50-250W> |
Dimensions | <eg - 60x12x16 in (HxWxD) > |
Approx Weight | <eg - 40kg (88 lbs)> |
Recommended Materials | <eg - MDF, Birch Ply> |
Schematic/Blueprint
Please attach schematics to this wiki page. You can then use the [IMG] tag to display them inline. Please don't be afraid to attach Gerber files to the page as well.
Note: There is a bug in the wiki right now where you can't add attachments to a wiki after 30 minutes.
Bill of Materials
Either list them in this section or attach a file to the page that people can download.
Note: If this project uses other projects as components (maybe a crossover/amp/driver from another thread or wiki, please list them here).
Simulations and Analysis
Embed the images for your simulations here along with descriptions for each of them so people know what you're talking about.
Construction (Steps / Tips / Notes)
Is there anything peculiar about the design that a builder might want to know about? List them here? Or do you just want to give us a step-by-step build plan; that works too.
Project Modifications
Do you have some small modifications to suggest for the project that could improve it? Please list them and tell us why they improve the design. If this is discussed in a thread, please link the thread URL here....
Modification 1
Cross the streams!
Modification 2
Install a flux capacitor!
Code for this template (copy/paste)
To create a new loudspeaker project, simply copy the text below, create a new wiki page/article (preferably with the name Speaker:ProjectName) and paste the text into your new page. Voila!
Code:
[TABLE] | border="0" cellspacing="5"
| [B]Name[/B] || <Project/Speaker Name>
| [B]Type[/B] || <Subwoofer, Dipole, Multi, Electostatic etc>
| [B]Application[/B] || <PA, Reference, waking the neighbors...>
| [B]Speaker Count[/B] || <1-1,00,000>
| [B]Approx Cost[/B] || 100,000,000 GBP
| [B]Designer[/B] || <Original Designer>
| [B]Thread[/B] || <URL to the discussion thread>
[/TABLE]
[H="1"]The Project[/H]
[H="2"]Introduction[/H]
[H="2"]Goals[/H]
[H="2"]Specifications[/H]
[TABLE] border="0" cellpadding="2" cellspacing="0"
| class="tcat" | Name
| class="tcat" | Description
| Freq Range || <eg -6dB at 27Hz and 33kHz>
| Freq Response || <eg 34Hz 28kHz ±3dB on reference axis>
| Dispersion || <eg - Within 6db of reference response>
| Horizontal || <eg - 60 degree arc>
| Vertical|| <eg - 10 degree arc>
| Sensitivity || <eg - 90dB spl (2.80v, 1m)>
| Harmonic Distortion || %THD or plot
| Nominal Impedance || <eg - 8 Ohm, min 2Ohms>
| Crossover Points || <eg - 300Hz, 4KHz>
| Power Handling || <eg 50-250W>
| Dimensions || <eg - 60x12x16 in (HxWxD) >
| Approx Weight || <eg - 40kg (88 lbs)>
| Recommended Materials || <eg - MDF, Birch Ply>
[/TABLE]
[H="2"]Schematic/Blueprint[/H]
[H="2"]Bill of Materials[/H]
[H="2"]Simulations and Analysis[/H]
[H="1"]Construction (Steps / Tips / Notes)[/H]
[H="2"]Project Modifications[/H]
[H="3"]Modification 1[/H]
Cross the streams!
[H="3"]Modification 2[/H]
[H="1"]Reviews[/H]
[H="2"]Review 1[/H]
Thumps!
[H="2"]Review 2[/H]
Music to my ears!
[H="1"]Build Threads[/H]
Have you built this project? If so, please add the URL to the thread that you started to show off your build.
[LIST]
[*]URL to my uber build 1 thread
[*]URL to my super dooper build 2 thread!!!
[/LIST]
[H="1"]Related Group Buys[/H]
[LIST]
[*]Thread 1234
[*]GroupBuy:XO1234
[/LIST]
This page has been seen 4,433 times.
Created by onLast updated by on
- Contributors:
