Hi! i have been planing to build an ESL design, and i've chosen to start with the "jazzman" design, because it's pretty well explained, and i've no experience with ESL, so, it's a pretty good starting point, but, i am really on a tight budget.
With the budget in mind, i was planing to buy this transformer:
Antek - AN-0506
but... it's been discontinued, and it has been replaced by this one:
Antek - AS-0506
how much will affect this change in the ESL?
Thanks!
Antek - AN-0506
Antek - AS-0506
Thanks!
I would suggest not to use the AS version or any shielded version of a transformer for ESL use.
1. The electrostatic shield adds capacitance to the transformer this helps to lower the impedance even more as seen by the amplifier at the higher frequency's, This is not good!
2. The insulation between the shield and the HV winding is inadequate for ESL use as it is just some Aluminium tape applied right on top of the HV winding around the circumference of the transformer with only one (maybe two in some spots) layers of 2mil mylar tape.
Upon a core saturation test of a AS-1206 this insulation had failed shorting about 7 or 8 turns of the top layered winding Shorting the transformer.
Luckily I was able to disassemble the transformer and repair the winding and continue to do more testing.
Although it is now modified from its original state I have the the same amount to LV winding turns on it using some speaker wire.
I will be posting some pictures of this later on tonight sometime here,
Testing Your Transformer and Using the Transformer Test Jig
As I get going I will be explaining what the parameters mean and explore someways to improve the transformers performance and different configurations.
jer
jer
I would suggest not to use the AS version or any shielded version of a transformer for ESL use....
Huh, I had not read the Antek description carefully. There are actually two shields on their AS transformers.
The one you mentioned, which is wrapped around the transformer after it is completely wound, has it's ends connected to form a shorted turn.
This is sometimes known as a "belly-band" shield and is used to stop the core and windings from radiating EMI to nearby ciruits.
The other shield is in between the primary and secondary windings to minimize interwinding capacitance.
This is referred to as a faraday shield. It must NOT form a shorted turn.
The farady shield in between the windings should be fine for ESL use since it was tested for 3500Vac. It will, however, probably increase the leakage inductance somewhat compared to the non-shielded version of the transformer just because it adds thickness between the primary and secondary. Will be interested to see what you get for leakage inductance measurements.
The outer "belly-band" should definitely be removed for ESL use and is evidently not that difficult to do based on your description.
So, maybe still useable for DIY with a little more effort.
Thanks for the reply!
I'm sorry if this question is stupid... when you are referring to "HV winding" you are referring to the winding that's on the "outside" part of the transformer right? And what's needed to do with this transformer to be able to use with ESL it's remove the metal plate on the top (magnetic shield), and remove the mylar on the outside of the transformer? or the aluminum tape and the mylar thats between the HV winding and the LV winding?
Sorry if i bother you, i don't want to screw up anything haha
The HV Winding is on the inside closest to the core.
It is the 120V windings and remeber that we are using them in reverse now.
As what would be the Primary (120v) Winding is now the Secondary Winding in our use of the transformer.
I did finally post those pictures in the other link as I had promised and the removal of the shields is very straight forward and causes no damage to the transformer.
jer
jer
I have not tested the 0506 myself.
But the 1206 doesn't measure too badly at all.
However it does exhibit a dip at about 10Khz in the FR when the 120V windings are tied in series.
I am not sure if this is caused by the limiting resistor in my test setup or how it will effect the system as a whole.
It seems that this dips corresponds to the peak in the impedance curve.
I will be looking at this a bit closer to verify it.
Posted is a picture showing these dips from the input/output ( I believe) of the transformer.
I forget what value of resistor I used.
The FR curve is flat when the 120V windings are open or in Parallel.
The Screen shot was done before I had the mishap and was measured in its stock form from the factory.
It was one of the very first measurements I did with it.
I am in the process of remeasuring it for about the 24th time and documenting my measurements and how I got them.
It has been a slow process as I want to be sure that I am getting consistent results and repeatability to verify my range of values.
I have posted some preliminary Impedance curves here for you to take a look at,
http://www.diyaudio.com/forums/planars-exotics/161485-step-up-transformer-design-6.html#post3404300
These curves were made with the secondary winding's (120V) left open and not connected.
Connecting them in parallel there is no change in the curve.
Connecting them in series will cut the high frequency impedance approximately in half as this doubles up on the secondary capacitance.
The addition of the capacitance from the ESL'panel will drop this part of the curve even more depending on the capacitance value of your panel.
On the low frequency side of things the impedance is quite low and the value of inductance of the primary winding (6V) determines this.
As I get going I will explore some ways that may to help improve this.
Removing the shields is very easy to do and doesn't effect the quality of the device as it is.
It is unfortunate that I damaged my part before I got to get a really good handle on what these shields were doing to my measurements.
But, I can just as easily add them back on once I get some base measurments with the basic core as it is now.
I was using my CrownDC300a at full power (115Vp-p) using test tones when it failed.
This is a very heavy test situation and most likely will never see this kind of abuse using your average amplifier playing music.
And even less likely using two or more cores.
The second picture shows the dip as well as THD from the output of the secondary at 40Vrms in to the primary of the transformer.
This is a extreme test and I am not sure how accurate the THD figures are as I later found out the the Realtek ALC892 on my motherboard is not very good at all by just using a standard loop back test.
The third picture shows the FFT of the output of the transformer at full power at 2400Hz this includes the amp of course.
At lower levels the THD is very low and much much more lower than this.
I will have more on this later as calibration is very critical for a very accurate result of the THD figures.
At normal levels in many cases I could not find any more added distortions that had any significance above about 600Hz to 1Khz or so and it got better as the frequency got higher.
I will take a closer and more refined look at this later.
Even as they are it is still much lower than most dynamic drivers at this very high voltage level !!
The last four pictures show the input and output voltages at the onset of core saturation.
They were at full power just before any flat topping of clipping from the amplifier at 330Hz, 304Hz, 270Hz and 240Hz.
I didn't get any screenshots of the primary currents and that was the next set of tests that I was doing when the transformer failed.
Thus I was watching the currents when I connected the electrostatic shield and had forgot to disconnected it when I started a sweep tests as it was in the saturation range when it failed.
Just for the record the primary currents did rise considerably when I connected the shield.
By as much as 30% to 50% or so but that is all I have on that for now.
This is solid indication that the shield adds unneeded capacitance to the transformer for ESL use.
All of these test were made with no extra capacitance added and was with only the transformers self capacitance.
FWIW
jer
FWIW
jer
HolmsImpulse FR-THD-Phase Transformer-Green -20Vrms amp out-red.jpg142.4 KB · Views: 476
information about transformers
I was wondering if it was possible to get good information about Antek transformers. I mean easy to understand measurements.
I give an example of what i like to see. Look at the pictures of an Audiostatic transformer i made (just the 1:150 transformer, no mirrordrive or filters C or R)
So i like to see what happens with a different load en what the saturation will be at frequency X. The impedance curve is really important for me, i don't like to use expensive amplifiers because a transformer or transformer/esl combination is not proper designed.
I forgot to tell that not every transformer has identical frequency response for the both phases.
I measured a Sowter1:60 transformer (without load)
I am curious to see what the Anteks do for the 2 secondary windings (115+115V).
I posted this information in post 7.
The First 2 pictures are with the 120V winding's in series as I had noted the dip at about 10Khz.
This dip is not there when the 120V winding's are open or in Parallel.
This dip still exist's even with the shields removed.
Here are two more pictures of a comparison of the 120V windings in series and parallel.
The yellow line is the impedance for a Series connection with green line for the phase.
The red line is the impedance for a Parallel connection with the blue line for the phase.
The only thing that is changed in the comparison of the two curves is the position of the peak of the impedance curve, and, the halving of the impedance at higher frequency's due to the doubling of the winding ratio and/or doubling secondary capacitance from the series connection.
If another core was added to increase the ratio by 2, having the primary's in parallel would cut all these impedance's, again, in half as well.
I have checked all of the configurations using another set of cores as I only have one of the AS-1206's from Antek.
I will be taking a closer look at this at a later time after I finish my latest thread of how to find the parameters of a transformer thread.
I have found that the double stacking method that I have used in the past shows a good compromise for getting a fairly high transformation ratio without having to low of an impedance for the amplifier to drive using power toroidial transformers.
I have done some Spice models from the data of my measurment's and the curves are right in alignment to what I have measured.
I don't have any of this data organized to present at the moment, as I am re-doing this in a step by step method in the new thread that I have started on ESLDIY.
Once I get them all together I will gladly post them here as well.
Sorry that it has taken so long as I have many projects going on at once again.
This always happens when I am trying to concentrate on one thing !!!!! He,he,he
jer
P.S. The glitches are caused by my Flakey ALC892 motherboard sound chip.
It is from the output side of the chip as I can see it dropping out while I am monitoring the signal on my oscilloscope.
jer
Many times large measured differences like you are showing are due to unexpected side effects of the measurements setup...in particular AC ground reference. Once I started using a differential probe, large measured differences(dips or peaks) between windings went away, leaving only minor differences that could be explained by differences in leakage inductance, winding capactance, or winding to winding capacitance.
I posted measured response for two Antek AN-0506 driving 1200pF load here:
http://www.diyaudio.com/forums/planars-exotics/225959-toroids-esls-4.html#post3306102
I can post response and impedance for other load combinations later if you are interested.
Oh, speaking of impedance, it is best to stick with the lower wattage(50W) Antek transformers as they will have higher turn count on the 6V winding which will be used as the primary for ESL step-up use. Primary inductance increased with number of turns squared. The larger 100W Antek has about half the primary turns, so 1/4 the impedance at frequencies in the 200Hz - 400Hz crossover range.
Power handling at core saturation for the AN-0506 can be found here:
http://www.diyaudio.com/forums/plan...p-up-measurements-part-1-2-a.html#post2823635
General method of estimating power handling of small power toroids used for ESL step-up here:
http://www.diyaudio.com/forums/planars-exotics/186011-diy-bass-transformer-esls.html#post2520512
I would be interested in seeing that data Bolserst.
I have been thinking about this a lot lately.
The physical measurement the the 100 Watt core don't seem to line up with what Antek says it is supposed to be.
It is a bit smaller than what I was expecting.
The antek core is 80mm in dia. and the core area is about 22.5mm X 35mm if not a little smaller.
This comes to 7.875 cm^2 of core area.
It is only slightly smaller than the 210 watt cores that I have been using at a 90mm dia. and about the same core area !!
jer
P.S. I just re-read your dimension figures of about 4cm^2 of core area and I had interpreted them wrong sorry about the confusion.
jer
Many times i see transformers who are not semetrical wound, the Sowther transformer for instance, and that is what you see also in the measurments.
Thanks for explaning but still i find it hard to read. To many lines in your graphes and some axes are lineair will it would be easier if it was logorithmic. But it is very good that people as you measure.
jer
I expect very low impedance at high frequency because 1200pF is very much load for 1:75
Indeed. Impedance is < 1 ohm at HF.
This is due partly to the large capacitive loading, and partly due to the fact that with low leakage inductance the XL/R ratio dictates only minimal resistance can be put in series with the primary before overdamping the resonance.
For the dual Antek setup, the damping resistance value needs to be kept < 1 ohm to avoid overdamping the HF resonance. However, often larger resistance value are used to roll of the HF response to compensate for the rising response of wide, flat, unsegmented panels.This is quite different from the situation for segmented panels where you can use transformers designed with much higher leakage inductance which allow larger damping resistance values before overdamping the resonance.
I'll see if I can dig up some impedance plots tomorrow as well.
The software I was using at the time was SimpleS,
http://www.diyaudio.com/forums/soft...peaker-impedance-tool-simpes.html#post3393589
I was using the first version and I have not used the latest issues yet.
The frequency scale is set to log and the Impedance is in a linear scale.
The impedance plots that I posted here,
Are of one test as described with the graphs re-scaled within the program using the same test data to show a better resolution of the impedance in those areas.
Since then I have been getting better results using the newest version of REW.
http://www.diyaudio.com/forums/software-tools/231754-help-required.html#post3416181
jer
jer
I calculated 2.35Ohm at 10khz if the transformer has no influens except the 1:75 ratio.
I would not like to have such low impedance. Not many amplifiers are suitable to drive such loads.
Yes, 2.35ohm if leakage inductance and winding capacitance is ignored. Actual impedance will be significantly less. Most solid state amplifiers rated for 4 ohm loads seem to have no problems if the impedance drops to 1.5 - 2.0 ohm in the top octave since there doesn't tend to be high amplitude audio content there.
Using the parastics posted for the Antek-0506 it is easy enough to calculate response and impedance with good accuracy using this spreadsheet:
http://www.diyaudio.com/forums/plan...101-electronics-challenged-2.html#post2555863
In the attached plots, C= ESL capacitance, R= resistance in series with primary
Pic #1: Shows impedance and response trends for increasing capacitive load with R = 0 ohm
Pic #2: Shows trends for varying R, with C = 1200pF
This is the typical capacitance for a "jazzman-style" flat, unsegmented ESL, for which the Anteks are used.
Note that R = 1 ohm provides a -3dB slope in the top octave which is exactly what is needed flatten the +3dB slope of the on-axis response of an ESL line source. Reduction in R might be desired if listening is done slightly off-axis.
Pic #3 and #4: Shows trends for varying C with R = 1 ohm and 2 ohm.
Pic #5: Shows impedance and response trends for increasing capacitive load with R adjusted for maximumally flat stator response.
- Planars & Exotics
- ESL hybrid
