This is my go at an external power supply for the SL-1200.
After a conversation with Wayne Colburn of Pass Labs, learning that he has made a few SP-10 PSU for in-house use, a few things became apparent - Get the bridge diodes out of the TT and just have DC on the umbilical. Use 1N4007 diodes, for whatever reason they sound the best, in this case even better than exotic high-speed diodes. Snub the bridge on the AC side with a .22uF film cap. Use multiple stages of RC filtering.
The biggest improvement is of course, no transformer vibration on the platter, easily done merely by locating the transformer outboard of the TT chassis, and this is what I was originally planning to do - but converting umbilical to DC wasn't much more work.
Does it sound good? Of course! And the best part is that I'm not even done yet, the stock regulator hasn't been replaced... (mainly because I ran out of time...)
The first thing to be done is remove the bridge diode and snubber caps.
These were located in the holes now visible.
An umbilical is added. The white 3rd wire is capped off, but still there if I need it for something in the future. The bare metal wire is the shield drain, to be attached to ground.
Fused IEC plug, switch, microphone connectors used for the umbilical.
All to be placed into this ABS enclosure.
There is no reason not to use the stock transformer, it's the proper voltage, soft-mounted, has a beautiful mu-metal shield, and is free with the purchase of a turntable.
(3) 4700uF 63V volt capacitors, (2) 10ohm 3W resistors, .1uF polypropylene bypass cap, all wired up in a CRCRC filter. Why those values? I had them on hand. If I needed to buy new, I would probably use similar values.
And here it is with the bridge to the side. (The yellow is the transformer secondary.) The eagle-eyed among you will notice the 1K bleeder resistor across the cap bank.
The final configuration of the umbilical attachment to the PCB.
The insides after the modification. I utilized the now unused AC power switch to switch the strobe.
A few zip ties to attach the wire to the studs for strain relief, and of course the obligatory ferrite clamp.
The PSU schematic
This is stage one of my PSU modifications, a different regulator of some sort will be next....
EDIT - and here it is:
After reading this fantastic article - Using 3-pin regulators off-piste: part 1
I have installed the first LM317 based regulator in my SL-1200. There is not a specific schematic in the article, look at the one on page 1 of the 'off-piste' article, and all you do is replace R2 with a Zener reference and make sure you include C2.
I did mine point-to-point and covered up all in heatshrink as I don't want anybody copying me directly, as it's a point-to-point salad of wire and tape. Do as I say, not as I do and all that...
It works wonderfully, sounds great, and took about 15min to install.
Here it is... not particularly exciting.
Lift the motor PCB and remove the old pass transistor and wires. (You could just cut the old wires and splice if you desire)
It mounts in the same position as the old transistor.
Don't forget some kind of insulator under the regulator - the old transistor was a 'full-pack' and did not need an insulator.
The regulator needs to be grounded here, at the turntable center ground.
Schematic
Questions or comments warmly solicited.
Thank you for looking.
The PSU schematic
Schematic
