The YARRA Preamplifier/HPA for Melbourne DB Group Buy
I have an extra Yarra power supply board built up and it seems to be the right voltage for a Pearl II phono stage (26 to 35 volts at 100 ma). The pearl has its own regulators on the boards. I was thinking of using the Yarra PS board for the Pearl II. The pearl article says the positive rail will be sourcing more current than the negative rail. Is that a problem? Is there any reason the Yarra PS board should not be used for a pearl II?
There is no issue with one rail using more current than the other, as long as within the range of the power supply. Each rail is provided by an indepedent trafo secondary and its own cap multiplier. 100mA is no problem for a Yarra PSU.
I did wind up building the Pearl 2 using the Yarra power supply. The results are very good. No noise at my chosen low output moving coil gain, and a big, warm sound. Thanks for your earlier feedback.
Founder of XSA-Labs
Joined 2012
Here is the BOM, as built for the ACP+ board.
This prototype board has a trace error - you need a jumper at location shown on schematic:
attachment.php
Here is how I did the jumper:
attachment.php
  • ACP-M2X-BOM-as-built-April-2020.zip
Yarra 2 Pre Update?
Hi X,
Any update on Rev 2 of the Yarra pre you teased us about late last year? Is it on your radar, with any design coming along yet. Or, have you been busy with other projects. Just thought I'd ask. I remember you offering a date window of late this year. Anymore insight into the project status you can mention?
Hi X,
I have just changed my trafo to 22Vac output, i am trying to get a standard +/- 24Vdc rails for most of the daughtercards.
However, i can only manage to get minimum +/- 30.8Vdc from the lowest pot positions. I can't get any lower.
Is there anything i can do, to achieve +/-24 without changing out the 22vac trafos?
Is it safe to use 30v rails for those daughtercards? Hakuin, Melbourne and H2 etc..
Founder of XSA-Labs
Joined 2012
Hi Meanie,
I run Melbourne at 30v, and have also run WBA18 there. Some of the other ones like Hakuin need 24v, and may run at 30v but will require some adjustment to setpoint resistors. Related to Redjr's question, we are working on the "Regulated Yarra PSU" which uses 78xx format TI TPS7A4xxx LDO regulators, and with that, we can get +/-24 easily As the original Yarra PSU is a cap Mx based PSU, it was not designed to provide regulated voltage, only ripple-free voltage. There may be a resistor or pot change that can get the lower voltage. Let me look into it.
@Redjr: we have many many variations of the next Yarrra proposed and JPS64 is working on the overall architecture. One thing we are wondering is if folks would like their Yarra to have DAC modules, Bluetooth, balanced in and balanced out, etc
Joined 2014
Hi Meanie,
I also run 22v trafos in the Yarra capMx psu. The way I reduced the voltage is increase the CRCRC resistors on the daughter board itself to lower the voltage.
My PCA’s use 47R and 33R in those locations for approximately a 7-8v drop. I don’t remember what my Hakuin values are. Use Ohms Law to calculate what the resistor values need to be for your voltage drop.
Enjoy!
