finally got round to swapping them out
Finally got round to swapping the 10 X 2SK170BL out for the 2 X 2SK209GR on adapters 4 matched and 6 un matched
Works very good and the dc off set is lower than the 2sk170bl's so it looks like a better matched quad
sounds really good indeed
20210106_100534 by glenn jarrett, on Flickr
20210106_100454_001 by glenn jarrett, on Flickr
20210103_151909 by glenn jarrett, on Flickr dca by glenn jarrett, on Flickr
Hi Salas
Happy New Year
Yes its a bit fiddly at first but i soon got the hang of it with a pair of tweezers
and a big magnifying glass
i let the fets warm up for 30 seconds then tested with 10v 100R sorted into idss groups
then soldered onto sot23 adapters then tested again with 10v 100R on breadboard 10 at a time
again once set up power on then leave them for a few minutes then measure the voltage across 100R
then ran the trace on the dca 75 a bit of a faf but worth it
would be quicker with 10x sot23 test sockets on veroboard but i cant find any and the peak ones are £20 a pop !
Happy New Year
is the focusrite scarlett solo 2 in 2 out ok to use with ARTA & REW ?
The Scarlett Solo series is alright for one channel line level test loop. Spec is the same as the fully grown Scarlett which is dual line level equipped.
Has to do with this PSU's betterment when burning more internal current. Lowering output impedance and rail modulation harmonics from the load.
Most users found 200mA a good compromise before it gets more and more thermally inefficient for smaller and smaller subjective benefits returns.
Great, thanks for the answer. Almost ready with a 200mA version. Looking forward to compare it with my standard B1.
Good luck and let us know your findings. Pictures are welcome.
I recently decided to build a Mezmerize Buffer. However, when it came to ordering the PCB's from the store, I was in for a shock. I live in the UK, and found that I had to spend $200, to order from the store (the post brexit position). This meant that I would have to buy 8 units. I don't need 8 Mezmerize PCB's. So, if anybody wants to purchase from the UK I could have 6 PCB's for sale. The price, less UK import tax, is $217.09, So it would cost you 217.09/8 plus tax.
If there is anything else someone wants from the store of "low value, below $200, we may be able to work this out. However this is a one off suggestion to get me the Mezmerize boards
If you are interested please PM me.
https://flic.kr/p/2kpwzeE20210106_100534 by glenn jarrett, on Flickr
https://flic.kr/p/2kpAoJB20210106_100454_001 by glenn jarrett, on Flickr
https://flic.kr/p/2kpAoH420210103_151909 by glenn jarrett, on Flickrhttps://flic.kr/p/2kpAYhEdca by glenn jarrett, on Flickr
Hi Glenn.
Great job!Beautiful.Did you use 2pcb for replacing 2sk170? When soldering back to back on this sot23-3 pinouts are being different if soldered back to back in single pcb.How did you do it?.Thanks and regards Umit
Oh I see,it is like this right?
Google Görsel Sonucu
It seems D and S pins identical.
So soldering back to back on single pcb will be ok.
Then it is great. I have thousands of 2sk209gr.And hundreds of this adapter.Now I should buy a tester but peak one seems a bit pricey.And our customs charges much too.Any China alternative? Thanks and regards
you dont need a peak just use the same method as testing idss on ordinary 2sk170bl the problem is the sot23 test sockets i have a peak one but it would be a lot quicker to test say 10 at a time all at the same temp but i cant find any for sale be careful some look like sot23 but are 6 pin
Yes testing 10pcs together would be very nice but we can not find any.Do these adapters are enough for cooling ?
I thought building pcb single sided paralelled and other side copper for cooling.But maybe it may not be necessary.
Have you measured temperature of 2sk209s by Ir thermometer?How many Celsius above the ambient temperature?Thanks for your help
- The diyAudio Store
- Mezmerize B1 Buffer Preamp
