2N3055 the early years
I know that with common ICs, mask exchange agreements became the norm but was that done at the single transistor level of did each manufacturer design their own version of the 2N3055 from the ground up?
Cheers
Ian
Probably. But power transistor mask layout isn’t rocket science. At least for stuff this basic. If the process is different enough having the other maker’s mask set won’t do you any good either. Jellybean transistors and op amps, digital logic and such - if your process has a similar FLOW through the line, and makes devices which are good enough, then you could use the mask set. You still get different flavors of say the 5532 op amp from the different makers. Like the original Signetics beat everybody’s. But most were good enough to use industry wide.
The MJL3281 does NOT use the same mask set as the 2SC3281. The die is about 25% larger. Don’t believe me? Crack them open and see. And the capacitances do measure more. They made it as big as the 15024, probably (speculation here) because their equipment was tooled up for it and they wanted it to handle as much power as they could. Their competition was Sanken, and you know what their LAPTs can take. It’s still the same shootout today (and I still think Sanken shot themselves in the foot by discontinuing the MT200 package giving the advantage back to ON). What they acquired from Toshiba was the recipe, or at least some of it. The die layout is trivial by comparison.
FWIW BD130 was an "European" 2N3055 equivalent in all important specs, I used tons of them and treated them as the same.
Why would a proud European Company use American registration codes for sales in their own market?
Would be same as Philips/Siemens/Mullard/etc.labelling their double triodes 12AX7 instead of ECC83 :)
Of course there is not a "single" 2N3055 spec either, many different ones (different manufacturing processes) along the way.
For me, focused on abused Guitar amps, BD130 were an excellent version, slow but robust, and would gladly use them if I found a dust covered humid box of them in some seller´s basement, go figure ;)
Cheers
Ian
I have no privileged info about that, but I would lean towards the latter: second-sources generally had some improved characteristics over the original, which would have been hard to sustain with just good manufacturing/sorting.
This means that additional ingredients probably went into the recipe
Here is an example of a datasheet from a Philips databook:
The databook dates from 1977, but the DS was filed in 1974:
Here is a listing of manufacturers from a 1980 D.A.T.A. book:
Here are some vintage examples of 2N3055, mostly from European origin (the one on the front with the faded marking is SSI).
Also included is the light alloy version from Moto (1971):
One more, from 1974:
And another one, exact date unknown but also seventies:
Reactions: 1 user
In the above pic, the one with the Motorola M was aluminum. The others are steel and solderable if yiu were so inclined. The aluminum TO-3 was supposedly only good for 5000 thermal cycles and no you could not solder to the case. Motorola did make a domed top hat steel TO-3, but only for a couple of years in the late 80’s. It looks like the one on the far right in the bottom pic could be that type. Those weren’t easily solderable either because they were polished. Too smooth. The rough steel ones like early RCA lent themselves to soldering with an X-rated iron.
In their 1973/74 data book Siemens lists the same transistor (single-diffused) with identical specifications but three different markings:
BD130 - PRO-Electron designator for Standard / Consumer types
BDY39 - PRO-Electron designator for Industrial types
2N3055 - Jedec nomenclature (for International Customers ?)
whether they were any different in quality is not mentioned, prices were ...
Reactions: 1 user
Thomson-CSF (now ST) made a 2N3055 and loads of other RCA devices with the same specs. I suspect these were under license from RCA.
Mullard/Philips also had a BDY20 device with similar specs to the 3055.
And to your earlier post - the 2N3055H was the original RCA 2N3055 (slow but robust) when they moved to epi base devices.
Reactions: 1 user
Account Closed
Joined 2018
At that time there was present three price ranges for the 2N3055 in the old catalogues from 70s from Conrad, Völkner, RIM and other suppliers:
1) Motorola (Now OnSemi) - most expensive (mostly above RCA, as I recall right)
2) Other branded versions like SGS/ATES, Valvo, Siemens, TFK, ITT etc. - a little cheaper
3) not branded versions (i. e. without logo) - cheapest available versions.
In retrospective also at those days issues like mentioned under
https://www.diyaudio.com/community/threads/counterfeit-transistors.115281/https://www.diyaudio.com/community/threads/my-transistors-original-or-copy.82638/probably was already present, especially in case of the brands like MOT and RCA.
I've got a matched set of 4 Bendix QP-8 TO3's from the outputs of a 1967 HH Scott amp.
Supposed to be the same as 2N3055's.
Neurochrome.com
Joined 2009
Certainly true.
Even IC masks (or at least the layouts used to generate the masks) were made with tape-on-velum film similar to how PCB layout used to be done. I used to work with folks who'd done layout that way and they weren't that old.
Tom
