I didn't know it, thanksRule of the thumb using transformers: if you want lower distortion, the transformer impedance must be at least 4-5 times grater, than source impedance.
Listed 1:1 transformers are "high" primary voltage, high impedance line input ones.
I've a question, in parallel single ended mode (313ohm, 2.6v), it can directly drive an integrated amplifier with input impedance of 10k or 100kohm (pot impedance )? Or is it desirable to have a lower output impedance to to get a better impedance matching hence better sound.
Tell me yours, thank you.
Aec Connectors RJ-255ABKPL(PF)G-TEF-BK, they're hard do find, I get them directly from the Taiwanese manufacturer, but some speciality audio parts store carry them, like:Anyone know the part number for the rca jack on the dam1941 pcb? I'd like to be able to match it.
https://www.audiophonics.fr/en/rca-...inlet-rca-for-ic-gold-plated-pair-p-8156.html
ThanksAec Connectors RJ-255ABKPL(PF)G-TEF-BK, they're hard do find, I get them directly from the Taiwanese manufacturer, but some speciality audio parts store carry them, like:
Please see manual page 8Is it possible to disable input auto sensing?
Just finished building the Power, Buffer, and Display boards and assembling the dam1941 system. Everything is working fine and sounds great. I won't be using the head phone feature. Am I correct in assuming that it is safe to cut-off the display board at a point beyond the mounting hole at 6.695"?
Yes.Just finished building the Power, Buffer, and Display boards and assembling the dam1941 system. Everything is working fine and sounds great. I won't be using the head phone feature. Am I correct in assuming that it is safe to cut-off the display board at a point beyond the mounting hole at 6.695"?
Some time ago Soren posted the the bagplate of the Soekris dac1541 which as the same cut out size. I've attach the Autocad dwg with those info. I haven't made a case yet, they should be correct but in case double check them.I'm ordering front and rear panel face plates for the assembled DAC. I'd appreciate part numbers for the TOS and USB2 jacks so I can get accurate size & cut-out specs. The RCA and BNC information was provided preciously.
One question: How can I do a true factory reset ? I realized that my set=filter... Commands are still there after flashing firmware/filter package 1.23. So, this is not a complete erase and rewrite...
Backround of my question: I played around with some cuatom dilters and strange enough i got now a highly attenuated signal, but only in sampling frequence 96khz.
My first Dam1941(older one) does not behave like that, so i want to be sure, that any misbehaving custom filter setting are erased and that I get the same volume behavior no matter which sample frequency i feed the 1941 with.
Enter uManager, do command "set" without parameters.After connecting the serial interface, I did a set mode = parallel, then I went out and turned off the dac. I turned the dac back on, but I'm not sure if it's in parallel mode, is there any way to check if it's switched to parallel mode?
Reload 1.20 stock 4K filters, available on soekris website.One question: How can I do a true factory reset ? I realized that my set=filter... Commands are still there after flashing firmware/filter package 1.23. So, this is not a complete erase and rewrite...
- Vendor's Bazaar
- dam1941 - Next Gen Discrete R-2R Sign Magnitude 24 bit 384 Khz DAC module
