There are 100 in the store already, and in process of being listed.
If you download and install MicroCap as described in the article, you should be
able to run this simulation and you can play with it, altering the values, running
overlayed curves for ranges of values and so on.
A good opportunity to learn MicroCap, which I think is the easiest thing for
beginners and lazy people like me...
I also have EQ files for some specific full range drivers, so I will post them as
I have time to go through them.
