Isn't the fact that it is the only model you created in millimetres rather in inches like other models?I don't see anything wrong with them. Can you post screenshots of what your slicer is showing or something to help me understand what the problem is?
I will have a screenshot to show what I see when import model to printer software
Use a professional SLA printing service and the results will be pleasing. I like JLC PCB, there are others. However it would be nice is the files were in the universal standard metric of millimetres
I save it as mm for you below.
Uploading the STEP files will give the correct unit/scaling, and also looks like it will bypass going through the wiremesh representation of the STL files.
Lucky me the place where I work for we do have 3d printers and SLA resinUse a professional SLA printing service and the results will be pleasing. I like JLC PCB, there are others. However it would be nice is the files were in the universal standard metric of millimetres
You can easily see two models ps and no psI don't see anything wrong with them. Can you post screenshots of what your slicer is showing or something to help me understand what the problem is?
One has visible lines which were printed. The other one is perfectly smooth and prints smooth.
Both of those files were generated at the same time, so I'm not sure why there would be a difference. And my printer didn't do anything strange with the ps version. I think your slicer is doing something odd. Do you have pics of the prints? If you unselect the non-ps version so they are both grey do you still only see lines on one?
Probably program in which you opened STEP file has changed the resolution of surfaces (triangles size). At this moment I'm preparing 3D waveguide model for CNC routing in AutoCAD and you can see how coarse or smooth surface can be. AutoCAD has FACETRES variable to define resolution, probably your printig program also has something similar.
If I would do this rough model it would have visible triangles in reality...
Yes they persists.If you unselect the non-ps version so they are both grey do you still only see lines on one?
One saved in Inches (no ps) and one in mm (ps)Both of those files were generated at the same time, so I'm not sure why there would be a difference.
They were both generated at the same time from the same model, and both are in inches. I'll download them and look at them in my slicer, but something has gone wrong with one of your files, by the slicer or something. Looking at them in F360 just now, they look fine.
Those saved in Inches working fine. It metric version gave me this result.So how about the one I converted to mm for you?
When uploaded to 3d printer software the ps version when open as Imperial was very little. Only when open as metric had proper size.and both are in inches
When I just opened those files in freeCAD I see them normal way. Same size and both smooth.
On Monday I can try your new links again.
- Open source Waveguides for CNC & 3D printing!
