From a technical aspect, which is better, EQ or trapping? I'm presuming the problem is a peak, if so, wouldn't it be better not to put the energy into the room in the first place?
I both do acoustic and electronic correction, because ideal acoustic correction requires way too much space and money. My concern about EQ correction is, distortion (H2) at different frequencies from the amp and speaker would be less linear with EQ correction, which would be audible as an artificial effect.
