800 Watt MOSFET Amplifier Module
Here is my latest amplifier module hot off the press!
Contact me for more info:
It is available now for purchase from my online store!
Cheers
Anthony
* Featuring Balanced XLR and Single Ended RCA input stage.
* Can be power from separate power supplies for the Input and Driver Stage
* Very low noise and distortion
* Unconditionally Stable
* Extra Heavy Duty three ounce copper printed circuit boards.
* Gold Immersion copper track plating
* Rugged high performance Toshiba MOSFET output stage.
* RoHs Compliant
* Very easy to install and get going
* Sound quality and reliability rivaling the best in the world
Preliminary Specifications
* 500 Watts RMS continuous sine wave into 8 Ω
* 800 Watts RMS continuous sine wave into 4 Ω
* 1200 Watts RMS short term sine wave into 2 Ω
* The HPA-nxV800 is 2 Ω Stable
* Biased into Class A/B
* Power Bandwidth 3.5hz to 250khz -3dB
* Slew Rate = 90 volts / microsecond approximately
* Dampening Factor At 100hz 8Ω = 1300
* Dampening Factor At 1khz 8Ω = 915
* Dampening Factor At 10khz 8Ω = 248
* RCA Single ended Input impedance 20kΩ
* XLR Balanced Input Impedance 40kΩ
* Differential Input Gain = 33.8dB
* Single Ended Input Gain = 28.1dB
* THD+N - Typically 0.003%
* Recommended Voltage Supply +-98 volts DC
* Operational Supply Voltage Range +-20v dc to +-105 volts DC
* PSU Power Transformer secondary windings 65vac (1200VA)
* Printed Circuit Board Dimensions 325mm x 50mm
* Minimum Recommended Conrad heat sink MF35-100 to MF35-151.5
Anthony,
A few questions
a) How is the loudspeaker protected?
b) What is the topology of the front end?
c) What do you bias the amp at?
Thanks,
Jam
Hi Jam
To protect the loudspeaker from possible damage, The LSP-One loudspeaker
orotector that I sell is well suited to be mated with the nxV800 module.
The front end topology is Complementry Differential folded cascode and Nested feedback loop included in the topology.
The output stage is biased to around 40ma per output device
so the total per voltage rail would be around 240ma.
I hope this helps Jam :)
Cheers
Anthony
Aussie Amplifiers
DIY Amplifier - Audio Amplifier Modules - MOSFET Amps - Audio Electronics - Power Amps
Anthony,
Bewdiful work, absolutely stunning!
I bet it sounds as good as it looks.......
Hugh
Thanks Hugh! :)
Yes it has an awesome sound quality, you just would not believe it
is a high powered amplifier by the way it sounds.
It has all the power and authority of a very high powered amplifier with the detailed imaging and sound stage usually attributed to much low powered amplifiers. :D
Cheers
Anthony
N4CR,
I am currently building a pair of subs as well based on the Exodus audio Maelstrom 18's and powered by the HPA-NVx1200's. Already got my amps but have yet to complete either build. Hopefully this weekend will see the completion of the sub cabinets. I will also post build pics when finished.
Regards,
Theo
Anthony -- I am just starting to build a dual mono amp using your NxV300's ---- I note in your photo that you use two chunky caps placed directly on each RCA input.
What type and value please?
Hi Dacall
The caps I used there are Sonicaps 3.9uf Gen 1.
I hope this helps.
Also please smed me photos and comments when you have finished
and I will post the on the web site Gallery.
Cheers
Anthony:)
Ekta Grandes -- just completed in time for Christmas -- looking forward to new Aussie amp build now.
