AckoDAC based on AK4499EQ
DAC upgrade with the newly developed Stratum II OCXO
Small enough to be mounted directly on board with short traces to DAC/DSP - all soldered down, no cables or connectors.
On-board conversion of oscillator sine output to logic level MCLK for DAC with minimal effects on the phase noise from close-in to floor - best in class performance!
Main inputs are re-timed directly to this reference clock for jitter elimination before going into the DAC chip. No external clocks or processing units required.
