amplifier unstable problem
I made a guitar amplifier as shown in the diagram, but when nothing is connected to the input of the amplifier, popping and crackling sounds come from the speaker for no reason. I couldn't quite figure out where and why the problem was. The yellow and blue probes connected to the oscilloscope in the video represent the signals at the power stage input of the amplifier. If you want, I can also send you the altium designer file.
Crackling can be either a faulty component or a poor intermittent connection (such as dry solder joint). Tracking down the culprit can be done with an (insulated) prodding stick or a freeze-spray. Since this is down powered-up you need to do it safely if the mains power is accessible.
Reactions: 1 user
