https://share.icloud.com/photos/0a3eq9YUx9tV4iAmI4-ycVxqQ
https://share.icloud.com/photos/008E3C5JVOYPHO_hEb-1kAXDQ
Here are two videos of worst channel, reminder this is not the channel I replaced caps on but this was how it first behaved until I changed Caps.
Only difference is that the repaired channel issue was resolved with adding clear tape around the RCA to keep the plug sleeve from contacting the chassis, again only one channel has this issue as seen in the videos, other channel no amount of pushing, twisting causes protection.
Could you post a closer photo of the older amp input stage area (near the RCA socket?so I could take a few pictures
Also from the other side of the board.
Some solderings look like cold joints from these photos but resolution is not good enough.
Best I could get since HS is in the way of back of board. Thanks for looking.
I tried to get hi-res, so let me know if you have issues viewing and I can downgrade the resolution.
Reminder: AMP 1 (bottom RCA) is the culprit on this amp board
+1Some solderings look like cold joints from these photos
Thanks for looking guys - I will pull out the board and go over as many joints as I can with the soldering iron and fresh solder (wouldn't that be great if that was the only problem??!!!). Sick kid yesterday, so I didn't get to do anything on the amp. Maybe today will be better - less work, more hobby!!!
I touched up all the solder joints on the top of the board and as many I could get to on the bottom, especially the RCA connectors. On the board that couldn't have both RCAs connected at the same time or I could force into protection by manipulating the plug.
Interesting result - still goes into protection with both inputs are connected - however, now I am unable to force it into protection by pushing the RCA fully in, or manipulating the plug.
So, I'm hoping this means that
- touching up the soldering will fix the fully seating and manipulating of the PCA problem
- replacing the 4 lower value capacitors (C16, C38 and C42 all 35V 22uF) and C41 (63V 22uF) will fix both inputs connected issue
Going to touch up the soldering on the board I previously replaced all the caps on, and still has the fully seating and manipulating RCA issue. I may be optimistic but this seems like it is progressing, albeit slowly.
My optimism has turned to despair... I replaced the 4 smaller caps (C16, C38 and C42 all 35V 22uF) and C41 (63V 22uF) on the channel I re-flowed solder on all joints. As part of the cap replacement I had to remove the board and was able to make sure all the joints were reheated and looked solid.
reinstalled and no change - still goes into protection as soon as you hook-up second pair of speakers.
Insult to injury... I reinstalled what was the working board (channel 6/7) and now it has the same symptoms. Fine with one pair of speakers (channel) playing, but as soon as second pair of speakers are connected, it goes into protection.
But, if I connected the bottom PCB speaker ground to chassis ground with a jumper (tried numerous place, but only works connected to the speaker ground for the lower RCA, amp #1), both channels play fine and listened to it this way for ~30 mins or more. No overheating heating, no sound issues.
I also tried to capture the protection behavior on my O-Scope, but it's too fast for the scope (or something, maybe me), because the signal is there and as soon as I connect the second RCA the scope trace/screen goes blank and doesn't come back until it come out of protection - then cycles until I unhook the RCA/speaker or turn off the amplifier. At no time during this cycling can I see/capture the sine wave again.
This seems to prove that it is losing ground somewhere (seems to point to lower amp channel), but I have checked continuity and resistance for all grounds - such as barrel of the RCA, the speaker grounds and the PSU ground (at both the PSU board and the plug from the PSU to the amp board) and I get continuity, around 0.4-ohms.
I was going to pull out the PSU board but there should not be a ground connection to the speaker ground here? I'll admit I'm getting frustrated and confused as to how there is an issue without any transistors, caps, resistors, diodes seemingly bad and all transistor voltages seemingly making sense.
I am at a loss of what to even try next? I guess I could try one of these older channels in the newer amp/PSU - nothing else connected and see if the symptoms go away, or follow the amp channel?
Anthem did brag about their ALM (automatic load monitoring) circuit mighty capability in protecting the amp.
Without a schematic diagram the troubleshooting would be much like fumbling in the dark.
I would go ahead and trace out a schematic by reverse-engineer it.
Otherwise, while using a conservative wattage dim-bulb tester, by disabling the protection may give you chances of having the amp stay in malfunction mode long enough for scope capture.
After fighting all these days and ending up with little positive development, perhaps leave it aside for a few days, have some good meal, good drink, good sleep, cool down a bit before further efforts?
By the way, from the pictures you posted so far, the ground connection on the output stage PCB seems to be, taking the speaker negative wire soldering joint as reference,
1. amp 1 and amp 2 speaker negative wires are not tied together immediately where they get soldered on the PCB.
2. there are two ground traces, one thick, one thin, coming off each of the speaker negative wire solder joints. The thick ones would travel the length of the PCB and join each other at the power inlet connector.
3. the thin trace coming off the speaker negative wire solder joint would go to the flat cable, in turn, go on to the respective front end of the amp.
I am trying to take my time, so I don't make anything worse.
I have been doing all this testing with a 150w DBT and afraid to take it off, because when it goes into protection it is drawing some significant current, as the bulb lights up 30-40% before the protection kicks in.
It is strange that working channels have gotten worse and the only variable is the DBT??? I wouldn't think two channels only, running through 150w bulb would cause enough current draw to trigger any protection. It's the biggest bulb I have.
I could have made myself a bit more clear.
What prevented you from being able to capture waveforms on a scope was the amps own protection kicking in and shutting the amp down before you had a chance of doing it.
What I was proposing is to disable that protection, by, for instance, disconnecting a relay coil.
What I meant by "using a conservative wattage dim-bulb tester" was to use a small wattage bulb in the DBT. Instead of a 150W bulb, perhaps try a 60W one, so as to prevent overcurrent damage while the amp's own protection is out of action.
Well I did something risky to try and prove out something... I plugged in the amp (no DBT) with only Channels 6/7 board originally working and listened to music for a couple days before working on fixing the other non-working channels.
The amp works fine with only one channel playing, but when I briefly plugged in the other channels speaker the DC offset jumps from 3-4mV to 200-300mV and the transformer starting buzzing. I could also feel/smell something was heating up, but I did this so briefly that couldn't pinpoint the origin, and I'm not sure I want to do this test more than the brief instant I did.
I can assume this proves something is broke and may be pointing towards the outputs, which measured okay with the DMM (but they are very difficult to get to with the orientation - so maybe my measurements have been misguided?
I am attaching the voltage measurements of Channels 6/7 (good channels - maybe) and Channel 4/5 (originally one of the two bad boards having this issue).
Pink dots on the Channel 4/5 voltages indicate that these voltages match the voltages I took earlier this year on the newer boards (did my best to match the transistors, newer board had slightly different location and numbering, but none were way off)
Key to the measurements:
- done with a DMM, one channel connected using a 150w DBT, no load, no input
- PSU voltage shown in top right-hand corner - after 10 mins of warm-up (voltage goes down 1V in this time from start-up voltage)
- channel designated in top left hand corner
- "*" are the inputs and are ECB, other small signal TO-92s are EBC
- Q40/41 and Q42/43 are MJE3350/340 and placed upside down on the board
- Q8/9 and Q23/24 are MJE15032/33 drivers and are BCE
- Q29 is a 2n5551 (EBC) and looks to be part of the protection and controls the relays on the output board
- Q44 is a MJE350 and upside down and ties to Q29
Continuing to narrow down the issue - tore apart my newer version amp to try the old PSU with a known working board (2 channels) --- of course, it works perfectly and rules out any power supply issue or chassis grounding problem.
So, I'm back to the older boards and trying to figure out what causes an issue only when both channels are connected to speakers? If I'm using a 8-ohm dummy load it works good with up to 30Vac on sine waves/music.
I have a decision to make - if I'm going to tear down the channel, I need to unsolder the ribbon cable (11-pin and 12-pin), because they will break if bent to much flipping the board back and forth soldering things - ask me how I know.
Thought this was going to be a "quick" fix, with a claimed 1-bad channel and blowing fuse I assumed outputs.
At least know, I can compare voltage "live" with working channel from other amp and see if I possibly missed something, since the working channel I was comparing to, has known gone bad.
Question - with 6 high DC channels on previous amp --- any chance bad input transistors 2sc3495 could cause the DC to ramp up, when it doesn't on a Dim Bulb? I'm sure it's a single to-92 leaking when current goes above idle - just flying blind without a schematic.
Attaching my DMM diode testing I did on Channels 4/5 and 6/7 - and I made notes of any weird readings, but again they both match, which at the time meant they were ok
Amp if Fixed!!! Playing music on all 7 channels.
Strangest repair I have had, possibly ever. After all the voltages and DMM testing of the transistors seemed to be good, but still going into protection with speakers connected (a load) I was getting frustrated and resorted to some guessing and shot-gun parts.
Best part is my first guess and set of parts repaired the amp. Looking back at my posts, couldn't figure out why it only happens with current, so I thought I'd start with the Input pair, thinking one may be bad and it's causing the amp to go out of balance and high DC. Pulled out the first (2) pair from channels 1/2 and guess what they both measured perfect on the DMM and the multi-tester, showing ~600mV Vf and ~1000 Hfe - right in line with the datasheet.
On a whim, had it apart so I might as well shot some parts at it - I put in (4) pairs of matched (with multi-tester, double-checked Hfe with BK Precision DMM) - and it powered up and played music first time!!! Had 8mV DC on one channel and 170mV on the other channel. That's fine, because at least it was playing and I could do some actual testing now. Proceeded to replaced the input pairs on all the other channels. Tested each channel individually and they are all working outside the case (which I couldn't get them to pass music without protection kicking in previously)
So success - except I still had 170mV of DC on channel 1/2 board - remember when I said these ribbon cables are the worst and most prone to failure on these amps, my opinion is proven again. Granted this is the board I have pulled out 4-5 times between cap replacement, resoldering and voltage testing, but nonetheless they should be flexible cables with connectors, not ridged ribbon cables.
Well apparently one single wire was loose on the AMP2 (top RCA channel) and in the process of finding it, 4 other wires broke - so actually good thing I had an issue to resolve, because it would have failed someday. But unsoldering, stripping and reinstalling those two ribbon cables takes at least 20-mins and very tedious delicate work to strip the wires without breaking the wire in the process, then you have to feed 11 and 12 wire ribbons into the output board and the input board carefully lining up the wires with the holes and then solder without any of them pulling out. Like I said - tons of fun!
Hoping this thread helps somebody repair their PVA-5 or 7, and maybe even their bigger brother MCA-5. I would think they are all a similar design, with different voltage parts and number of outputs.
Usually it boils down to something like this - the only question is "is this device worth that time and effort or should I buy the next one."Well apparently one single wire was loose on the AMP2
Want to clarify that was not the original issue, the actual issue was the 2SC3495 input pairs and I assume leakage/failure when current was applied. Worked at low volume, but with a speaker load and music above background level DC out of balance and the protection kicked in.
The one single wire issue was caused by me AND what I think it a flaw in Anthem's design to use these 30AWG solid wire (stiff) ribbon cables.
Do I think it was worth the trouble - I do, but that's because I like to work through a problem and fix it. I also have mentioned I bought a broken PVA-7 previously and repaired it and I like the sound, design and aesthetic enough to buy another one. So for me, yes - totally worth it. And knowing what I know now - if I do it again, the first order of business is to replace all input pairs on every channel - then see if there are any lingering issues to resolve.
- Anthem PVA-7 - Strange Oscillation
