Avast antivirus blocks Siliconray web pages
I have tried to access the Siliconray web site but my Avast antivirus blocks access. There appears to be some sort of infection present. I have included a screen grab of the Avast message.
Thanks for the screen shot. we had tried several antivirus tools but found nothing. Can you try to find the full url of the infected file foe me? It will be very helpful.
Another screenshot
Every single page is apparently infected. It seem to be Java Script in your footer.
Try to take off counter. I believe it must be http://count.51yes.com/ this webpage. Google says: last time suspicious content was found on this site was on 2012-10-31
<address><script language="javascript" src="http://count18.51yes.com/click.aspx?id=189062132&logo=6" charset="gb2312"></script>Powered by <a href="http://www.siliconray.com">SiliconrRay Development Team</a>.</address></div></div></div></div></div> <script type="text/javascript"> (function () {
var papDomain = (("https:" == document.location.protocol) ? "https://":"http://");papDomain+="www.siliconray.com/affiliate";
var papId = 'pap_x2s6df8d';
// adjust the ID iff it would conflict with an existing element
if ((function(elementId){var nodes=new Array();var tmpNode=document.getElementById(elementId);while(tmpNode){nodes.push(tmpNode);tmpNode.id="";tmpNode=document.getElementById(elementId);for(var x=0;x<nodes.length;x++){if(nodes[x]==tmpNode){tmpNode=false;}}}})('pap_x2s6df8d')) {papId += '_clicktrack';}
document.write(unescape("%3Cscript id='pap_x2s6df8d' src='" + papDomain + "/scripts/trackjs.php' type='text/javascript'%3E%3C/script%3E"));
</script> <script type="text/javascript"> </script> <script>$_SKIN_URL = 'http://www.siliconray.com/skin/frontend/default/default/';</script> <script src="http://www.siliconray.com/js/quickContact/jquery.js" type="text/javascript"></script> <script src="http://www.siliconray.com/js/quickContact/jquery_noconflict.js" type="text/javascript"></script> <script src="http://www.siliconray.com/js/quickContact/modalwindow.js" type="text/javascript"></script> <script src="http://www.siliconray.com/js/quickContact/quickContact.js" type="text/javascript"></script> <style> #mask {
