Just for clarification:
Did loading openssl.tcz via the UI fail?
Or did it work, but the script still failed afterwards?
UI says its already installed. Still cant get it to work :/
I made another clean image and resized to exactly 200MB this time. Usually tried more.
Do I need to do something with the md5 text included in the zip?
I unzipped and the imager only writes the img i think (using Raspberry Pi Imager v1.7.5).
Also tried with Win32 Disk Imager - 1.0.
I tried redownloading the files but still no luck. Should i go for the 32 bit version?
This is what i get (Sorry for posting something so long):
tc@pCP:~$ wget
https://github.com/JWahle/piCoreCDSP/raw/main/install_cdsp.sh && chmod u+x install_cdsp.sh && ./install_c
dsp.sh
Connecting to github.com (140.82.121.4:443)
Connecting to raw.githubusercontent.com (185.199.111.133:443)
saving to 'install_cdsp.sh'
install_cdsp.sh 100% |************************************************************************| 6225 0:00:00 ETA
'install_cdsp.sh' saved
### Create CamillaDSP config folders
cd /mnt/mmcblk0p2/tce
mkdir -p camilladsp/configs
mkdir -p camilladsp/coeffs
### Create default config
cd /mnt/mmcblk0p2/tce/camilladsp
echo '
devices:
samplerate: 44100
chunksize: 2048
queuelimit: 4
capture:
type: Stdin
channels: 2
format: S16LE
playback:
type: Alsa
channels: 2
device: "plughw:Headphones"
format: S16LE
' > Headphones.yml
/bin/cp Headphones.yml configs/Headphones.yml
if [ ! -f "active_config" ]; then
ln -s configs/Headphones.yml active_config
fi
### Install ALSA CDSP
cd /tmp
pcp-load -wil -t /tmp git compiletc libasound-dev # Downloads to /tmp/optional and loads extensions temporarily
Checking Dependancies for git.tcz...
Downloading git.tcz.dep....OK
Downloading curl.tcz.dep....OK
Downloading openssl.tcz.dep....OK
Downloading ca-certificates.tcz.dep....OK
Downloading expat2.tcz.dep....OK
Downloading libgcrypt.tcz.dep....OK
Downloading libgpg-error.tcz.dep....OK
Dependancy check complete for git.tcz.
Downloading: libgpg-error.tcz
Checking Dependancies for compiletc.tcz...
Downloading compiletc.tcz.dep....Connecting to repo.picoreplayer.org (172.67.157.97:443)
OK
saving to 'libgpg-error.tcz'
Downloading bison.tcz.dep....OK
libgpg-error.tcz 100% |************************************************************************| 94208 0:00:00 ETA
'libgpg-error.tcz' saved
Checking MD5 of: libgpg-error.tcz.....OK
Downloading: libgcrypt.tcz
Downloading diffutils.tcz.dep....OK
Downloading file.tcz.dep....OK
saving to 'libgcrypt.tcz'
libgcrypt.tcz 100% |************************************************************************| 400k 0:00:00 ETA
'libgcrypt.tcz' saved
Checking MD5 of: libgcrypt.tcz.....OK
Downloading findutils.tcz.dep....OK
Downloading: ca-certificates.tcz
Downloading flex.tcz.dep....OK
Downloading gawk.tcz.dep....OK
saving to 'ca-certificates.tcz'
ca-certificates.tcz 100% |************************************************************************| 144k 0:00:00 ETA
'ca-certificates.tcz' saved
Checking MD5 of: ca-certificates.tcz.....OK
Downloading: openssl.tcz
Downloading mpfr.tcz.dep....OK
Downloading gmp.tcz.dep....OK
saving to 'openssl.tcz'
Downloading isl.tcz.dep....OK
openssl.tcz 100% |************************************************************************| 1676k 0:00:00 ETA
'openssl.tcz' saved
Checking MD5 of: openssl.tcz.....FAIL
MD5 of tcz: 034a8f55e5325eafe5f11a879a99b8b5 openssl.tcz
MD5 check: h :nIDAit)d&$47[@{ۿ Downloading mpc.tcz.dep....OK
Downloading gcc.tcz.dep....OK
Downloading gcc_base-dev.tcz.dep....OK
Downloading gcc_libs-dev.tcz.dep....OK
Downloading gcc_libs.tcz.dep....OK
Downloading binutils.tcz.dep....OK
Downloading glibc_add_lib.tcz.dep....OK
Downloading glibc_apps.tcz.dep....OK
Downloading glibc_gconv.tcz.dep....OK
Downloading grep.tcz.dep....OK
Downloading pcre.tcz.dep....OK
Downloading bzip2-lib.tcz.dep....OK
Downloading m4.tcz.dep....OK
Downloading make.tcz.dep....OK
Downloading patch.tcz.dep....OK
Downloading pkg-config.tcz.dep....OK
Downloading glib2.tcz.dep....OK
Downloading gamin.tcz.dep....OK
Downloading libelf.tcz.dep....OK
Downloading sed.tcz.dep....OK
Downloading e2fsprogs_base-dev.tcz.dep....OK
Downloading libffi_base-dev.tcz.dep....OK
Downloading glibc_base-dev.tcz.dep....OK
Downloading util-linux_base-dev.tcz.dep....OK
Downloading zlib_base-dev.tcz.dep....OK
Downloading linux-5.15.y_api_headers.tcz.dep....OK
Dependancy check complete for compiletc.tcz.
There was a error downloading libasound-dev.tcz.
I cut the retries as this wouldve been even more text.
