Ok so I ordered the Dayton audio br1 kit and I have messed up the crossovers I have never done them before and like an idiot I clipped the leads down and glued the to the inclosure without checking it first. Is there a pre assembled cross over that I could use that would sound good or a cross over design that someone would be kind enough to give me detailed instructions on. I would greatly appreciate it, wouldn’t mind to cash app somebody a few bucks if need be. Thanks in advance
It's not clear to me from your description why you can't rescue the crossovers - is it only the glue that's the problem?
I can point out that the BR-1 crossover schematic and description are on Page 5 of the assembly manual and the parts inventory is on Page 2.
https://doc.soundimports.nl/pdf/brands/Dayton Audio/BR-1/pdf_Dayton Audio_BR-1_1.pdf
EDIT: The assembly instructions do say use glue, but I would have used suitably short screws inserted through the supplied mounting holes.
