Daphile - Audiophile Music Server & Player OS
I have an issue with Daphile recognizing my Synology NAS drives. Not sure this was answered since this thread is long.
Under Daphile storage setting , both drives always appear perfectly connected, of the internal 8TB drive inside the NAS and the USB one that connected externally to the NAS.
But in Daphile file manager, there is only one drive listed either the NAS or the USB one.
Do a re-scan, USB drive appears in file manager, and another re-scan, the NAS drive appears, but never showing both drives at the same time.
The USB drive is a NTFS, 2TB WD.
I use this address structure under network drives:
192.168.xx.xx:/volume1/private/Music -> as nfs-Type
This means I can see the NAS directly as a drive. Does that help?
Thanks RushHH
Not sure I described my issue properly :
The NAS has been working fine with Daphile for long time. I recently connected an USB hard drive to the NAS externally.
Now, only one drive can be seen in Daphile's file management, However, both drives are showing connected in Storage settings.
The drive that can be seen in file management will work fine , but after a re-boot , it disappears and the other drive is showing up ,
Both drives just do not work at the same time.
Hello guys. I’m brand new here. I’ve just installed Daphile on a Asus Eee PC. Seems all fine (added local file as well as Qobuz subscription) but I don’t see any “usb audio” under audio devices, only “ALC269VB analog” and “hdmi 0”. Is it normal until I plug a dac into the usb or should show up in any case? I’ve no dac yet and want to know if I can go this path, or need to buy a dac+streamer instead. Thanks.
Normal. Devices are shown when connected.
Not connected Not shown.
Is there a kind of "support forum" for Daphile? Cause I'm facing problems trying to install it on another machine and Google doesn't help at all. First attempt from flash drive it worked but assigned same IP address of the other machine. So I turned it off., next boot I pressed F1 to set a fixed IP, but then stuck on "waiting for network connection". Since then always stuck in this way, and, lately, not even asking anymore to press F1. I created a fresh new bootable drive with the latest version, same results. 😒
