Deluxe 4U faceplate option (8 M3 + 1 LED) - is this it?
Can someone help confirm the $399 silver faceplate option is the right one to allow this mounting?
And can you confirm if the LED hole is not actually a full hole (as in, it does not penetrate the front of the faceplate but could be drilled out later?)
I just want to be 100% sure before ordering. Thanks!
Deluxe 4U Aluminum – diyAudio Store
